Big Android problems - Need help! :/
Go to solution Solved by NPSTR107,
I found a way! I downloaded SMS Backup+ as an APK from https://github.com/jberkel/sms-backup-plus/releases
I installed it and am currently backing up!
I'm trying to fix a Oneplus X as it has been having storage problems, they don't support SD card as internal storage, and it's only got about 12GB of internal, which is annoying. (This is a secondary issue)
I want to factory reset the phone, but I need to retain SMS and phone call logs if possible. I know that there is a app for backing up these,
But, the main issue is, I can no longer install any apps to the phone as the Google Play store app has gone rogue. It's not in the app drawer or the apps list in settings.
FYI:
  • Android 6.0.1
  • 9.94GB used of 11.54GB
And, it's also getting this error everywhere (See attached)
"Those who are last are sideways and smiling". - Jeremy Clarkson
https://linustechtips.com/topic/1014684-big-android-problems-need-help/
1 minute ago, Zmax said:
Have you tried connecting the phone to your computer via cable and looking for the files you want to backup
The files on the phone aren't a problem, they're already backed up.
And look in you phone setting there might be a backup option.
I can't find any options in the SMS app to backup, which is the default Google Messaging app. And SMS's haven't backed up to G Drive either.
