Replace the Window with a solid Panel for Fans??
Hey Everyone,
Asking for a friend.
He has a Corsair Spec-03 case. He said he is sick of the window in the case and wants to replace it with fan. Is there anyway that would take a small mod or something that can be done to get this sorted?
EDIT - Or is there another case side panel that would work?
Main Rig - Case: Fractal Design Pop Air XL Motherboard: Asus TUF B650 Plus WIFI CPU: AMD Ryzen 5 7600 RAM: Corsair Nautilus 240 RAM: Corsair Vengeance 16GB 3000MHz32GB Corsair Vengeance DDR5 6000MHz  SSD: 1 TB 1TB Samsung 990 Pro NVMe
HDD: 2TB WD Blue  GPU: Asus RTX4070 Dual Evo PSU: Corsair RM850X
Corsair 200R Front Bezel Mod
See if the one on the opposite side works. Just flip it around. Then maybe find one on ebay.
Main Gaming and Streaming PC: http://pcpartpicker.com/user/Vinsinity/saved/TjwVnQ
Ultrabook and College Laptop:
XPS 13 9350:
i5-6200U
8GB RAM
Samsung PM951 250GB M.2 Solid State Drive
Workstation Laptop:
Sager NP8672 (P670SG):
i7-4720HQ
32GB (4 x 8GB) CORSAIR Vengeance Performance
Samsung 850 EVO 250GB M.2 Solid State Drive (Boot Drive)
Samsung 950 PRO 512GB M.2 Solid State Drive (Video Drive)
Crucial MX100 250GB 2.5" Solid State Drive (Secondary SDD Storage)
Western Digital (Blue or Black) 1TB 2.5" 7200RPM Internal Hard Drive (Storage Drive)
GeForce GTX 980M 4G
If he wants to just get rid of the window you can always try swapping the left and right side panels, not sure how easy it would be to source just the side panel.
The window on that case should be acrylic so he could probably just paint the window from the inside and if he wants to add a fan it should be quite easy to drill the 4 screw holes and a large circle for the fan to be able to intake air from the outside + get a fan grill on amazon so noone sticks their fingers in the fan while it runs.
