OOF if this is in the wrong place.
I was looking into building my own PC, mainly because my current PC is slower than my old Windows Vista laptop. I was wondering where to start.
Info:
1. For light gaming (online multiplayer and low RAM usage games) and school work
2. I already have a bunch of spare 2-4GB RAM chips lying around
3. Not very experienced at this stuff
Budget: $1000 ish
Thanks in advance for any help!
Don't forget to use the "Quote" feature or mention me ( @Gegger) if you want me to see your reply!
Community Standards // Forum Quickstart Guide // Floatplane // Forum FAQ // The Parrot Gang
Banned by Linus in the "banning game" thread who added insult to injury by putting this crap in my sig >(
WE ARE THE DARK SIDE Don't be a light theme peasant
             ........:oo:........
           o//ssssssssyhhysssss+////o               .''''''''''''''.
          mddmmm/::ddddddddddddddmmmyss::/mmN       |   PARTY ON   |
          o..+oodddmmmhhhhhhhhhhhdmmmmmdddooy       | ,............'
         h::oyyhddmmm+++///////////++++++mmmddy::s  |/
      Nyyo[[sddhyyyyy::::::::::::::::::::yyymmh//oyym
     h..:oohmm+:://///::::////////////////+mmmmms..sNN
     m++sddmmm+::hddhhy::+ddddddddddddddhhhmmmmmdhh+++d
    Nsssyyhmmhssooodmmhhh::+mmdyyyyyyyyddddddmmmmmmmmo::d
   mmd../mmmmmo::shhdmmhhh::+mmhooooooooyhhmmmmmmmmmmmyssdmm
  +++++smmdddo::///dmmhhh::+mmhooooooooooommmmmddddmmmdd/++m
 ``+hhhmmhoo/:::::oooooossymmhooooooooyyymmdoooooydddmmo//N
 ++:mmmmmy:::::::::::::/yyhmmhooooooooyhhmmd:::::+yyhmmyssddd
ooommmmmy:::::::::::::://ommhooooooooooommd:::::://shhdmm+..
yyhmmh++/::::::::::::::::+mmhooooooooyyymmd::::::::/++hmm+//
dddmmh++/::::::::::::::::+mmhooooooooyhhddh:::::::::::hmmysshhd
mmmmmdhhs::::::::::::::::+mmhoooooooohhhhhy:::::::::::hmmhhh``+
mmmmmh++/::::::::::::::::+mmdhhsooooodmm++/:::::::::::hmmsss``+
dddmmhoo+::::::::::::::::+dddddyssyyydmm::::::::::::::hmmsoo++o
dddmmdhho::::::::::::::::+hhdmmddddmmmmm::::::::::::::hmmsooNNN
mmmmmh///::::::::::::::::+hhdmmmmmmmmddd::::::::::::::hmmsoo++/
yyhmmdss+::::::::::::::::/ooydddmmmmmsoo::::::::::::::yddhyy::+
++ommmmmy:::::::::::::::::::ohhdmmddd/::::::::::::::::shhdmmsssNNNmmN
..+mmmmmy:::::::::::::::::::://shh+//:::::::::::::::::://dmmmmdoo+..o
``+dddmmhss+:::::::::::::::::::+++/::::::::::::::::::::::ooodddhhysshNNy++m ``+hhdmmdhhs///:::::::::::::::::::::::::::::::::::::::::::::yyymmmmmmmmo++hNNmdd ``+hhdmmdhhhhh+:::::::::::::::::::::::::::::::::::::::::::::::/hhhhhdmmmmmsoo... ``+ddmmmdhhhhhyyyyyyyyyyyo:::::::::::::::::::::::::::::::::::::+++++sdddmmdhhsss//+ ``+mmmmmhsshhhhhhhhhhhhhhy++/:::::::::::::::::::::::::::::::::::::::+ssyyydmmddd///hhd ``+mmmmmy::shhhhhhhhhhhhhhhhs:::::::::::::::::::::::::::::::::::::::::::::ymmmmmmmh../ ``+mmmmmy:://////////////ohhhyy+::::::::::::::::::::::::::::::::::::::::::///hddmmmhhs++s ``+mmmmmhssssssssssssssssydddddysssssssssssssssssssssssssssssssssssssssssssssdddmmmmmy::s ``+mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmhooh
https://linustechtips.com/topic/1013799-building-a-pc/
1 minute ago, Xereth said:
i5 8600k
gtx 1070
16gb ddr4 2400
overclockable mobo for the 8600k
750w psu
Corsair spec omega rgb
Good cpu cooler
Thanks! I'll look into it.
https://linustechtips.com/topic/1013799-building-a-pc/#findComment-12126223
AMD Ryzen 5 2600
MSI- B450-A pro Atx motherboard
G-Skill 2x8GB DDR4 2800Mhz
SSD 240gb And 1TB HDD
AMD RX 570 8GB GPU
550W Power Supply
        - AMD Ryzen™ 5 1400 Processor
        - Asus Prime A320M-K ATX motherboard
        - Zotac GTX 1050Ti 4GB OC Edition
        - Kingston 8GB DDR4 2133Mhz Ram
        - Corsair VS 550 power supply
        - Kingston A400 240GB SSD
                                                       - 1TB WD BLUE HDD Hard Disk & Samsung 320GB HDD(7200RPM)
        - CPU COOLER: Stock Cooler(AMD)
https://linustechtips.com/topic/1013799-building-a-pc/#findComment-12126268
2 minutes ago, Agent_Niraj said:
AMD Ryzen 5 2600
 AMD RX 570 8GB GPU
 550W Power Supply
Thanks!
https://linustechtips.com/topic/1013799-building-a-pc/#findComment-12126274
https://linustechtips.com/topic/1013799-building-a-pc/#findComment-12126296
https://linustechtips.com/topic/1013799-building-a-pc/#findComment-12126316
1 minute ago, Manderis said:
What kind of ram? I usually only have older stuff as spare and that would mean DDR3. If you don't have DDR4 sticks with decent frequency you might have to sell those spare ones and buy new stuff
I don't know, I'm going to have to dig them up in my drawer of RAM. I'm pretty sure they're DDR4, as they are from 2013.
https://linustechtips.com/topic/1013799-building-a-pc/#findComment-12126323
https://linustechtips.com/topic/1013799-building-a-pc/#findComment-12126325
2013 is most likely DDR3 because there was no DDR4 until mid 2014
Ok, I haven't looked at the drawer yet, I might have some DDR4 lying around too though.
https://linustechtips.com/topic/1013799-building-a-pc/#findComment-12126338
Info:
Budget: $1000 ish
Also $1000 isn't a budget for "light gaming"
https://linustechtips.com/topic/1013799-building-a-pc/#findComment-12126349
I mean, my parents won't let me buy a good PC, but they said if I could, I should build one. I'm paying out of pocket (I don't have a job) and I have about $1000. Not Fortnite/CSGO type games though. I was just looking for a decent computer.
https://linustechtips.com/topic/1013799-building-a-pc/#findComment-12126365
Well $1000 is a good budget my budget is about £480 so...
Edited by Sentile
https://linustechtips.com/topic/1013799-building-a-pc/#findComment-12126370
OOF. A  year ago I couldn't have even bought a processor. If I could buy a PC I'd get a Acer Nitro 5 or Razer laptop.
https://linustechtips.com/topic/1013799-building-a-pc/#findComment-12126373
An RX 580 and 6 core R5 2600 is more than enough for light gaming, and will do fine for 1080p.
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  ($154.99 @ Amazon)
Motherboard: MSI - B450 TOMAHAWK ATX AM4 Motherboard  ($110.47 @ B&H)
Memory: G.Skill - Aegis 16 GB (2 x 8 GB) DDR4-3000 Memory  ($96.99 @ Newegg Business)
Storage: Crucial - MX500 250 GB 2.5" Solid State Drive  ($49.89 @ OutletPC)
Storage: Seagate - BarraCuda 1 TB 3.5" 7200RPM Internal Hard Drive  ($44.89 @ OutletPC)
Video Card: Gigabyte - Radeon RX 580 8 GB Gaming 8G Video Card  ($199.89 @ OutletPC)
Case: Fractal Design - Focus G (Black) ATX Mid Tower Case  ($55.99 @ Amazon)
Power Supply: Corsair - RMx (2018) 550 W 80+ Gold Certified Fully-Modular ATX Power Supply  ($54.99 @ Newegg)
Total: $768.10
Generated by PCPartPicker 2018-12-28 10:37 EST-0500
https://linustechtips.com/topic/1013799-building-a-pc/#findComment-12126939
Total: $768.10
Thank you!
https://linustechtips.com/topic/1013799-building-a-pc/#findComment-12128356
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  ($149.99 @ Amazon)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard  ($65.98 @ Newegg)
Storage: HP - EX900 250 GB M.2-2280 Solid State Drive  ($46.99 @ Newegg)
Storage: Western Digital - Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive  ($44.89 @ OutletPC)
Video Card: Asus - GeForce GTX 1070 8 GB Dual Series Video Card  ($304.99 @ Newegg)
Case: Cougar - MX340 ATX Mid Tower Case  ($44.99 @ Newegg)
Power Supply: Corsair - RMx 650 W 80+ Gold Certified Fully-Modular ATX Power Supply  ($59.99 @ Newegg)
Total: $814.81
Generated by PCPartPicker 2018-12-29 05:17 EST-0500
https://linustechtips.com/topic/1013799-building-a-pc/#findComment-12129712
Total: $814.81
Thank you!
https://linustechtips.com/topic/1013799-building-a-pc/#findComment-12129717
