https://linustechtips.com/topic/1013541-first-build/
4 minutes ago, LegendFrosty said:
sorry im new to this can you  explain why 2x4 is better than 1x8?
Using 2 sticks of RAM instead of 1 essentially means that you have more bandwidth.
When there are two lanes on a busy street, more cars can drive down it at once.
Not to mention, Ryzen likes having dual channel memory; performs a bit better. Just make sure that if you do 2x4 (or 2x8, or anything else) that you alternate the memory slot placement to ensure that dual channel mode is enabled.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
https://linustechtips.com/topic/1013541-first-build/#findComment-12124425
TYSM i didnt know that.
https://linustechtips.com/topic/1013541-first-build/#findComment-12124427
So its like a 2 way highway/road vs 1, so essentially more data can go to ram from CPU. However, you cant have 4 so even if you have 4 sticks, its still a 2 lane highway.
https://linustechtips.com/topic/1013541-first-build/#findComment-12124621
