Hello,
I am looking to upgrade my CPU, Motherboard and ram. i am think of going with a Ryzen 2600, but i am unsure what motherboard and ram to go with. I have been looking at the Corsair Vengence LPX CMK16GX4M2A2666C16 16GB and the gigabyte b450 Arous Elite motherboard. i am not looking to overclock or anything. Would this ram work well with the CPU and MOBO
Thanks.
https://linustechtips.com/topic/1013228-ryzen-2600-build/
7 minutes ago, CAL2000 said:
Hello,
Thanks.
should be fine
you canget faster ram for cheaper tho
if you dont want lights 97
https://pcpartpicker.com/product/FNprxr/gskill-aegis-16gb-2-x-8gb-ddr4-3000-memory-f43000c16d16gisb
if you want lights 109
https://pcpartpicker.com/product/PBPKHx/team-t-force-delta-rgb-16gb-2-x-8gb-ddr4-3000-memory-tf3d416g3000hc16cdc01
https://linustechtips.com/topic/1013228-ryzen-2600-build/#findComment-12121832
https://linustechtips.com/topic/1013228-ryzen-2600-build/#findComment-12121856
4 minutes ago, CAL2000 said:
Check out these one from Gskill
https://www.outletpc.com/sz1487-gskill-tridentz-rgb-16gb-2-x-8gb-288pin-sdram-ddr.html
Higher speed less price and it also has RGB in it
https://linustechtips.com/topic/1013228-ryzen-2600-build/#findComment-12121872
