my current build:
8 gb of ram gskills ripjaws
gtx 1070 8gb OC edition
amd 2600x cpu
GA-AX370-Gaming motherboard
1tb hdd
120gb ssd which has windows on it
600 watt bronze certified powersupply (looking to get gold certified for safety had a bad experience with a bronze certified one fried my whole set up)
can i get away with a 550 watt gold certified to power my system? i just dont feel comfortable on a bronze certified one anymore after it fried my whole system
https://linustechtips.com/topic/1012783-new-power-supply/
2 minutes ago, samorr11 said:
can i get away with a 550 watt gold certified?
What are you talking about exactly?
There are good 550W for cheap (Bitfenix Formula) ones and shitty/old ones as well.
Maker and Model is important!
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/1012783-new-power-supply/#findComment-12118619
reread i made the post more coherent. i want a trusted maker so bitfenix corsair evga etc. would anyone recommend a refurbished one as well? or is there safety issues there
https://linustechtips.com/topic/1012783-new-power-supply/#findComment-12118628
Yeah but what PSU are you looking at?
And "trusted maker" don't mean shit as they all can (and will) do more or less good shit.
And in Gold, the differences aren't that small either...
Of course not.
As they come without manufacturer warranty.
https://linustechtips.com/topic/1012783-new-power-supply/#findComment-12118678
Of course not.
im looking at the rosewill photon 650w gold verified
https://linustechtips.com/topic/1012783-new-power-supply/#findComment-12120284
A good quality 550W is more than you need, you can save the money or get a better unit.
The Rosewill Photon is unknown as it is not tested. The used plattform can be good or not depending on what Rosewill paid for.
Since you're in the US, you probably can't get the ones I'd recommend for a reasonable price (for example Cougar GX-F).
https://linustechtips.com/topic/1012783-new-power-supply/#findComment-12122506
It was tested: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story2&reid=405
It uses High Power Astro Lite, which was also used here: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=420
And here: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=466
https://linustechtips.com/topic/1012783-new-power-supply/#findComment-12122676
