Current Rig:
  • Quad Core AMD A8-7600 - Turbos to 3.8GHz
  • ASUS A68HM-K Motherboard
  • 16GB DDR3 RAM
  • GTX 1060 6GB
  • Cyberpower 400W PSU
Im looking to spend around £300 (GBP - Just under 400 USD according to google) and I put together this part list:
  • AMD Ryzen Six Core (I'm probably going to pick up one of the new 3000 series when they are announced at CES so I can only guess at specs and pricing for this) - Around £100 - £120
  • Any ATX Motherboard that is compatible (Again, I can only guess at specs and pricing for this until more details come out at CES) - Around £70 - £90
  • 16GB of G.Skill NT Series DDR4-2133 RAM
Everything else would be kept the same.
I use the system mostly for gaming however I do some photo / video editing from time to time. I'm looking for advice on which parts to get so I don't end up wasting all my money on a system that isn't being used to it's full potential. I've been told by a few of my friends that I should just save more money and buy an Intel however I believe that AMD is the better choice due to their price. Would appreciate some feedback on this.
Thanks & Have a Merry Christmas, IAmBlaZing
https://linustechtips.com/topic/1012638-upgrade-advice/
Sounds great, the ram I would change to 16gb 3000mhz Corsair vengeance ddr4 ram, cause ryzen loves high ram frequencies.
I am faster than 80% of all snakes
cpu: AMD Fx-8350
motherboard: GIGABYTE 970 (am3+)
RAM: 16gb ddr3 adata
gpu: AMD xfx rx 560 2gb
psu: 500w
storage: 1tb hdd
I am what you call “budget gamer”
https://linustechtips.com/topic/1012638-upgrade-advice/#findComment-12117598
Thanks for the advice, i'll keep that in mind when I go to buy the parts, think they are only £10 more than the G.Skill so thats perfect ❤️
https://linustechtips.com/topic/1012638-upgrade-advice/#findComment-12119092
