---Edited Post---
Should you run your AIO pump at 100%? It seems like the PC community is once again divided. On one hand we have those that say AIO pumps are meant to run at 100% at all times, and on the other hand we have those that say it could potentially harm your pump.
Which is right? My pump does not make a noticable differance running at 100% vs lower.
https://linustechtips.com/topic/1012618-aio-pump-question/
Why fix it at 100%? You need to get the fluid running because unlike air coolers, liwuid coolers have hardly any passive cooling effect. However low pump speed, say 30%, is already enough for idle.
Desktop benching:
https://linustechtips.com/topic/1012618-aio-pump-question/#findComment-12117468
Why do you want it to run at 100% all the time?
Unnecessary noise and power draw. Not to mention shortening the lifespan of the AIO by running the pump faster than necessary.
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
https://linustechtips.com/topic/1012618-aio-pump-question/#findComment-12117469
Mhm... Okay... Like always people in the PC community seem to be saying different things.
https://linustechtips.com/topic/1012618-aio-pump-question/#findComment-12117479
Who told you to run it at 100% ALL the time? That's like keeping your car pinned at 5,000 revs at every red light. It doesn't make sense.
HOLA NIGHT THEMERS
OTHER TECH I OWN:
https://linustechtips.com/topic/1012618-aio-pump-question/#findComment-12117486
Okay so the silent mode in cam software is at 60%. Perhaps I should let it be on silent then?
Do you know how to completely disable smart fan 5 settings in bios=?
https://linustechtips.com/topic/1012618-aio-pump-question/#findComment-12117489
I made a post on tomshardware. Two people answered and said it should be kept at 100% at all times, and your fans could be set at a lower option.
https://linustechtips.com/topic/1012618-aio-pump-question/#findComment-12117494
Should I let the pump be able to go up and down, or should I have it set at a static rate at like 50%?
https://linustechtips.com/topic/1012618-aio-pump-question/#findComment-12117505
My aios were always at 50%. My custom loops are either 50 or 40. No reason to have a pump at 100 unless its compensating for a bad build.
https://linustechtips.com/topic/1012618-aio-pump-question/#findComment-12117813
2 hours ago, spree said:
tomshardware.
There's your problem.
On topic: back when I had an AIO, I always ran it at 50%. I never had any temperature issues of any kind.
https://linustechtips.com/topic/1012618-aio-pump-question/#findComment-12117901
From my experience people over here usually have more knowledge. However, there's seems to be lots of topics regarding this and most of them do say that you should run your pump at 100%.
I'm confused and I think either way it wont make much of a differance. I will probably keep it at 100% for now unless someone gives me a good reason not to.
https://linustechtips.com/topic/1012618-aio-pump-question/#findComment-12117998
Only reason I have it at 100% is because that's what majority of people (from my research) have said.
Probably won't make a big differance either way. The 5 year-warranty is there even if you run it at 100%.
https://linustechtips.com/topic/1012618-aio-pump-question/#findComment-12118002
Less heat, power and noise. Is that good enough?
https://linustechtips.com/topic/1012618-aio-pump-question/#findComment-12118004
Power - Don't care
Heat - how could it possible give more heat when running at higher %?
Noise - No differance to my ears.
I guess it doesn't really matter and I'm overthinking this.
https://linustechtips.com/topic/1012618-aio-pump-question/#findComment-12118007
my aio has been running at 2000rpm for ever now and no issues, running it at fullspeed seems pointless to me
Specs: Ryzen 9800X3D 5425MHz - ASUS TUF RTX 4080 super - G.Skill Trident Z5 Neo 64GB 6400MT/s CL26 -  Gigabyte X870 AORUS Elite Wifi7 ICE - Torrent Fractal Design white - EVGA 850W Supernova G2 80+ Gold - Noctua NH-U12A
https://linustechtips.com/topic/1012618-aio-pump-question/#findComment-12118011
Power, dont care.
Well if something uses more power it produces more heat.
But if you don’t care about anything, nothing matters.
https://linustechtips.com/topic/1012618-aio-pump-question/#findComment-12118013
Okay. So is it better for my to make a curve on which it goes up and down, or use a static mode to always keep it at say 60%?
https://linustechtips.com/topic/1012618-aio-pump-question/#findComment-12118020
Would you recommend to use a fan curve or static mode? Is it "easier" on the pump running at 60% at all times or something like 30% at idle and higher under load?
https://linustechtips.com/topic/1012618-aio-pump-question/#findComment-12118030
What does better mean to you? You get zero benefits running it at 100.
You don’t care about anything else so it really makes no difference.
https://linustechtips.com/topic/1012618-aio-pump-question/#findComment-12118033
My reply wasn't about running it at 100%. I was asking if I should use static or a curve for my pump. I've seen some people say it's more "stressful" for the pump to be going up and down in terms of RPM.
And what the heck is your problem? Turn off notifications on this post if you're going to be a douche.
https://linustechtips.com/topic/1012618-aio-pump-question/#findComment-12118037
I’ve already said what I would do. As I’m currently doing it.
I can’t say what’s better as you’ve said none of the issues running at 100 bother you.
If theres no benefit of 100%, making a curve would be the same.
https://linustechtips.com/topic/1012618-aio-pump-question/#findComment-12118055
I'II take your advice. I will set the pump at 60% (lowest cam software allows me) and be done with it.
Thanks for your replies.
https://linustechtips.com/topic/1012618-aio-pump-question/#findComment-12118127
Does your mobo have a aio header or just using a fan header?
Does the mobo have its own software? Cam isn’t the greatest when it comes to control.
https://linustechtips.com/topic/1012618-aio-pump-question/#findComment-12118134
My mobo have a pump header, which I connected it to. However, it was a 4pin header and the nzxt comes with a 3 pin.
My mobo does have a fan control and pump control.
https://linustechtips.com/topic/1012618-aio-pump-question/#findComment-12118139
