Suspect my GTX 1080 is dying. After using it with my triple 1440p 144hz monitors for a while, even not gaming, one or all of the monitors start going red. Sort of like the gamma settings get out of control and becomes almost totally unusable till I restart computer. New monitors and new display port cables that are properly secure.
What is happening here?
https://linustechtips.com/topic/1012433-monitors-going-reddish/
Any specific time it occurs like 5 mins after restart?? Did it start as soon as you got new monitors or just recently?? Try rolling back drivers and checking cable connections. Also see if the problem persists with just one or two monitors connected. If you have another monitor then try it with that. Beside what monitors do you have now?
https://linustechtips.com/topic/1012433-monitors-going-reddish/#findComment-12116189
The monitors are new, cables are the right ones and secure. Usually, it happens after using it about an hour or so after being off for a while on all of the screens. When I restart it either goes away on all of them for a shorter amount of time then comes back and sometimes jumps from one monitor to another for no apparent logical reason. All drivers are up to date... have not tried rolling them back though. - seems like the gou is dying. Also, seems to take forever sometimes for all of the monitors to all come on at the same time.
https://linustechtips.com/topic/1012433-monitors-going-reddish/#findComment-12116199
