Need help with rtx 2080 PLEASE
Go to solution Solved by Dylank12277,
1 hour ago, MandoPanda said:
Just let it run its course. Grab a snack, take a nap. You can quote me when it finishes.
Hey I just finished doing all of the installations and it finally works. Thank you so much man you are a life saver. You're the best lol
  • i have recently bought a rtx 2080 and am trying to use it in my computer but it is not being detected. all it says is Microsoft Basic Display Adapter. i am really frustrated and i have no idea what to do. i have the asrock z390 extreme4 motherboard with 16gb g-skill trident z, i5 9600k, 750w powersupply. the drivers are not installing as well.
https://linustechtips.com/topic/1012311-need-help-with-rtx-2080-please/
Did u plug it in?
Current Pc Parts:
-CPU: Intel i7-9700k
-GPU: EVGA RTX 2070 black edition
-CPU Cooler: NZXT Kraken x62
-Mobo: Asus z390-E gaming
-Ram: Corsair Vengeance RGB pro 32g @3000MHz
-Storage: Samsung 850evo 256Gb
-Storage: Toshiba 1Tb 7200rpm
-Case: NZXT H500
-Extra: NZXT Hue 2
3 minutes ago, MandoPanda said:
Reseat the card and make sure you are plugging in all of the power connectors for the card.
i have reseated the card three times and made sure all the plugs are connected which are the 8 pin and 6 pin connectors if i am correct.
1 minute ago, Dylank12277 said:
how would i do so?
Go to the manufacture's website and make sure all of the drivers are up to date for it.
Rest In Peace my old signature...                  September 11th 2018 ~ December 26th 2018
Have you been restarting in between reseats? Make sure the power cables are plugged in all the way and to the right ports on the PSU.
5 minutes ago, Dylank12277 said:
how would i do so?
Go here:https://www.asrock.com/MB/Intel/Z390 Extreme4/index.asp#Download
and download INF driver and install.
I have a semi modular power supply from evga and I have the cables plugged into VGA 2, should it be in VGA 1?
Try it
Since it looks like something shows up under "pci device", it might be the card. Do you have any other Pcie devices plugged in?
I ended up uninstalling the drivers with ddu and the 2080 was not recognized under the menu but the gtx 980 was. I'm really not sure what to even do now
3 minutes ago, Dylank12277 said:
No but I did try a gtx 980 and it did the same thing
Well since it shows up as pci device right click on that and see if it has an option for you to update drivers. Then choose to search the internet.
