i have i gaming pc i made i have bean using is for 3-4 months now when my pc started not turning off it was strange it will say it is going to shutdown then the screen will go black but my pc is still ruining plz help i have all drivers and McAfee anti virus have scan my pc so i don't know maby you do i just wanna have my pc back up and ruining
https://linustechtips.com/topic/10122-plz-help-asap/
Does the screen go black as in no signal or is your computer just outputting a black screen?
I had this same problem.
I'd click shut down.. windows shutting down and monitors would go black after a few seconds but fans kept going so I just held down the power button for a few seconds until the computer turned off.
The forced shut downs never caused any problems and it stopped happening when I bought a new PSU.
“Snorting instant coffee is the best,” said Kayla Johns, 19, of Portland.
https://linustechtips.com/topic/10122-plz-help-asap/#findComment-109503
  • 10 years later...
Mcafee at this point is basically bloat ware....don't use it.
With regards to your actual problem there's a couple of things that I would suggest.
The first is making sure that the quick startup feature is turned off in Windows.
The second is to reset your bios to default , There's a few things in there that can cause issues with power states etc that might stop it properly shutting down.
Someone else with a bit more knowledge might come along if those don't work.
CPU : Ryzen 7 7800X3D @ -30mv All core
CPU Cooler : Thermalright Frozen Prism 240mm AIO
Mobo : Asrock B650m Pro RS Wifi
Ram : 32GB (2X16GB) Lexar Ares 6000MHZ CL 28-36-36-68
GPU : MSI Gaming X Slim 4070Ti Super 16GB ( 308W PL +140 Core +1000 Memory )
Storage : 2TB Verbatim Vi5000 Gen 4 NVME
PSU : Thermalright TG-750w 80+ Gold ATX 3.0 PCIE 5.0
Case : Fractal Design Pop Mini MATX
Case Fans : 3 X Thermalright TL-C12C-S RGB
Monitor :27" Samsung Odyssey G5 2560 x 1440 180 HZ IPS
Keyboard : HyperX Alloy Core RGB
Mouse : Corsair M65 Elite RGB
Headset : Corsair HS35 Gaming Headset
https://linustechtips.com/topic/10122-plz-help-asap/#findComment-16053335
You are replying to a post from 2013. Please stop.
https://linustechtips.com/topic/10122-plz-help-asap/#findComment-16053410
I realised afterwards , Somehow read 2013 as 2023.
Sorry dude.
https://linustechtips.com/topic/10122-plz-help-asap/#findComment-16053424
