Help plz
Go to solution Solved by kelvinhall05,
Probably unplugged a SATA data or power cable from your boot drive/motherboard.
So I was just looking around in my computer and I unplugged my graphics card and plugged it back in(I have no idea if that had anything to do with it) and I turned on my computer and it said no operating system found and idk what to do or why it happened
I turned on my computer before at like 2 am and it worked fine
If anyone could tell me maybe how to fix it or idk
https://linustechtips.com/topic/1012116-help-plz/
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1012116-help-plz/#findComment-12113743
My guess is that you knocked on of the sata cables. Or for some reason the boot drive order in the bios changed.
So ensure all cables are firmly in place.
Checking bios should be easy depending on specific mobo. It'll be under boot/chipset settings or drive management, something to that effect.
-アパゾ
https://linustechtips.com/topic/1012116-help-plz/#findComment-12113749
Check SATA plugs, check BIOS to make sure its trying to boot from your harddrive/SSD, check power cables as well.
https://linustechtips.com/topic/1012116-help-plz/#findComment-12113750
When I pulled it out I probably knocked one loose
My computer boots now
Thank you
Edited by ScArEdDeMoN404
Miss spell
https://linustechtips.com/topic/1012116-help-plz/#findComment-12113755
