I keep getting this error when trying to run certain installations even though I'm 100% sure nothing else is installing
I was told that I should try disabling Windows Installer but every option is disabled as if I'm not allowed even though I'm the administrator
any fix? ;~;
https://linustechtips.com/topic/1011766-another-installation-is-in-progress/
If you look at the processes tab or the startup tab of the task manager (CTRL-ALT-DEL), then you might get an idea of what is causing your problem.  Under the processes tab, look for something it says is running at 100%.
