FPS LOCK
Go to solution Solved by saladcrack,
Probably either via Nvidia control panel you can force Vsync or enable it in whatever game you're playing if they have the option (most do). If you're playing a more competitive game or a game where the developer has bothered there might be an option to actually limit the framerate.
i5 12600k | ASRock Z690M-ITX 32GB Corsair Vengeance LPX DDR4 3200MHz | EVGA 2080 Super Black | Samsung 970 EVO Plus 500GB + 980 1TB | Corsair RMx 650W | Thermaltake Tower 100 White
https://linustechtips.com/topic/1011375-fps-lock/#findComment-12107848
