As in you're trying to use 3 sticks of RAM?  Or you want to replace the current 1x8 with 2x4?
If you plan on using all 3, it would probably work, but probably won't be a significant improvement.  To my understanding, if I'm wrong I hope someone will correct me, but if you run an odd number of RAM sticks it will run in single channel.  I believe you'd actually be better of just using the 2x4 on it's own because you'd be able to get the full performance out of them by running dual channel.
https://linustechtips.com/topic/1011271-help-with-ram/#findComment-12107202
