I am looking to buy a new pair of over ear headphones as well as a new pair of IEMs. My budget for the over ears is between $100-150 US and my budget for the IEMs is between $50-75. I am seriously considering Audio-Technica ATH-M50s
for the over ears but I'm open to other options. For the IEMs I don't have a clue what to buy. Any recommendations are appreciated.
https://linustechtips.com/topic/101087-headphone-recommendation/
Do you prefer open or closed for the over ears?
My Build Log on PCPartPicker FX-6300, ASUS M5A78L-M/USB3, MSI 7870 GHz Edition, Corsair Vengeance LP 1x8GB, 1TB WD Blue, Fractal Core 1000 USB 3.0, Corsair CX600, and my most recent addition that I've had forever and isnt new is a 80GB WD800 for Linux, Lenovo ThinkPad X131e, ASUS Transformer TF300T, Galaxy Note 3 Sister dropped it in a puddle I now have to use a Samsung Brightside, Beyerdynamic DT990 Pro 250ohm version, Blue Yeti  #TheRealKEH-JEFF | "Sometimes, if were lucky, in Australia, a family has 2 kangaroos to pick up the kids with" - marto | Your entry here | Remember kids; just because Linus has a video on it, doesn't mean that its the best choice | ts3.wferr.com the best TeamSpeak Abide by the CoC | Looking for build help? Read this before posting |
https://linustechtips.com/topic/101087-headphone-recommendation/#findComment-1351643
I have a pair of Westone UM1's for a while and they're quite good for the ~$70 price tag for what they are. They sound great for vocals but the trebles roll off very early and the bass extension isn't the greatest, so if that isn't your thing, the UM1's may not be for you and you may want to consider options like the Klipsch S4 or the Creative Aurvana 3 instead :P
Current PC: AMD FX8320 || PNY GTX 770 || 2x4GB || ASUS M5A97 || Corsair TX 750 V2 || Asus Essence STX || CM Storm Enforcer
Peripherals: Logitech G500S || Cooler Master Quickfire TK || Audio-Technica AT2020 || Focusrite iTrack Solo || Q701 + DT990 Pro
https://linustechtips.com/topic/101087-headphone-recommendation/#findComment-1352359
Such as?
Shrue SRH440's are an amazing value (can't stop recommending them, got them on friday, loving them, went from M50's to these). If you can, get the pads for the 840's too, they fit on the 440's and they imrprove bass, comfort and isolation.
Sony MDR V6 or 7506.. or you could see if you find the Beyerdynamic Custom One pro at a discount.
Reviews: JBL J33i   M50s   SRH440   Soundmagic PL50
https://linustechtips.com/topic/101087-headphone-recommendation/#findComment-1353858
