Need help balancing pc upgrades
Solved by SpiralTTGL,
motherboard doesn't serve to get you more performance ryzen doesn't even overclock well stick with your motherboard, swap the nvme ssd to a regular sata ssd and get 1tb since games aren't getting any smaller, definitely upgrade the power supply but that price seems a little high but whatever, case is up to you and ram is fine but could prob find cheaper at same speed
