Hello, I recently found an old unused 700gb hard drive which I would like to use in my laptop. There is one problem though, it seems to not work. I take my hard drive with windows 10 installed out of my laptop and then put in the 700gb hard drive and turn the computer on. The hard drive sounds like its spinning but the screen is blank and it nothing happens for like 10 seconds and then the power button light just turns off and everything stops. I've tried changing the ram and stuff like that, the laptop works perfect with 2 other hard drives i have which each have windows 10 and 7. I've also checked the voltage and polarity of the hard drive and its the same as the other two so I don't know if its broken?
https://linustechtips.com/topic/1009964-hard-drive-not-working/
