-Moved to Peripherals-
I used to play at a high DPI, but ever since I got my Logitech G403, I've been playing at just 800 DPI with high sensitivities.
https://linustechtips.com/topic/1009860-high-dpi-vs-low/#findComment-12094365
High DPI is good for turning around really quick in games. If i use a controller my skills = potato because i'm so used to moving my mouse somewhere, not pointing a joy-stick at it (Yet i'm getting a switch.)
Not sure about you but I think my 7 year old CPU still rips
https://linustechtips.com/topic/1009860-high-dpi-vs-low/#findComment-12094379
same. i like having the options to slide it high with the click of a button in case i need it.
high dpi + low sensitivity is supsedly better if you have a high quality mouse and mousepad
https://linustechtips.com/topic/1009860-high-dpi-vs-low/#findComment-12094380
I've got a dollar store mousepad, but my mouse sensor is pretty much equal to the one found in the G502.
800 DPI + high sensitivity seems to be the sweet spot for me, and I've always played on a high sens.
https://linustechtips.com/topic/1009860-high-dpi-vs-low/#findComment-12094388
See you can have great band control and move it slow enough so it’s same as 800 dpi
https://linustechtips.com/topic/1009860-high-dpi-vs-low/#findComment-12094404
It really is a subjective thing, i like higher DPI, but i have friends that like reeeeally low DPI.
Project Diesel 5.0: Motherboard: ASRock Fatal1ty X370 Professional Gaming /// CPU: Ryzen 5 3600X  /// CPU Cooler: Scythe Ninja 5 /// GPU: Zotac AMP Extreme RTX 2070 /// RAM: 2x 16gb G.Skill Ripjaws V @3200mhz /// Chassis: Lian Li Lancool One Digital (black) /// PSU: Super Flower Leadex III 750w /// Storage: Inland Premium 1TB NVME + Toshiba X300 4TB
Peripherals: Mice: Cooler Master MM720 /// Keyboard: Corsair K70 MK2 SE (Cherry Silver), Blitzwolf BW-KB1 (Gateron Reds) /// Monitor: Acer XZ320Q 32' (VA, 1080p @240hz) /// AMP: Topping PA3 (Onkyo Integra A-817XD undergoing restoration) /// DAC: Weiliang SU5 /// Speakers: AAT BSF-100 /// Mike: Alctron CS35U /// Headphones: Blon B8, ISK MDH-9000
Living room: TV: Samsung QLED Q7FN 55' 4k /// Amplifier: Denon AVR-X2400H /// Speakers: DALI Zensor 7 /// Consoles: Sony PS4 Pro 1TB, Sony PS3 500gb /// LD/CD/DVD: Pioneer DVL-909 /// Power Supplies: Upsai ACF-2100T + GR Savage CDR2200EX
https://linustechtips.com/topic/1009860-high-dpi-vs-low/#findComment-12094422
