So i recently purchased an i7-8700k and want to start streaming, I mainly game on it and i want to start streaming games. I am going to build a new computer. So far i have the case(NZXT S340) the ram (16GB of Gskill TridentZ 300MHZ), 1 TB Hard Drive, GTX 1060 6gb, but i need help deciding on what Motherboard and what CPU Cooler to get. I am Looking To Get the motherboard For Under $100 and the Cpu Cooler For Under $60. I will be overclocking, so i want it to be cool and i dont really care that much about it being that quit i just want the best performance out of both of them. Thank you!
https://linustechtips.com/topic/1009690-need-help-for-motherboard/
Type Item Price
CPU Cooler be quiet! - Dark Rock 4 CPU Cooler $67.49 @ SuperBiiz
Motherboard Asus - ROG STRIX B360-H GAMING ATX LGA1151 Motherboard $108.44 @ Amazon
  Prices include shipping, taxes, rebates, and discounts
  Total $175.93
  Generated by PCPartPicker 2018-12-17 21:13 EST-0500
little bit more expensive but i couldn't find a mobo that had decent vrm under 100 dollars
as for the cooler its also a bit more but it will give you much better performance then a cheap cooler
if you want even better performance however i would recommend going with a dark rock pro or noctua dh15 however they are both out of your budget
1 minute ago, Happycowdance said:
Type Item Price
  Total $175.93
He'll need a Z370 motherboard or Z390 motherboard for overclocking as the B360 doesn't support it. For motherboard, probably something like a Gigabyte Z370XP will work out ok.
Just a reminder, a low end Z370 motherboard and mid-ranged cpu air cooler for an 8700k isn't going to allow for high overclocking.
print "Hello World!" ("Hello World!")
2 minutes ago, Happycowdance said:
Hmmmmm
Maybe just get the dark rock 4 instead of the pro 4, then spend like $130 on a mobo
Primary PC:
PSU tier list
How many watts do I need?
oops I was just looking at the price and the cooling for the vrams
go with what @fasauceome and @Airdragonz suggested
