  • 4 weeks later...
5 minutes ago, Timvdb said:
Here are the CPU clock speeds, and usages
It's fine. The CPU only turbos to 3.5GHz if one core is heavily used, otherwise it's 3.1GHz if all four are used. However unless it drops below 2.6GHz while under load, I can't call it a thermal throttle condition.
https://linustechtips.com/topic/1009459-cpu-problem/#findComment-12184496
20 hours ago, JasonBecker said:
Are you using the integrated Intel HD Graphics 530 or does your laptop have dedicated graphics?
I have a dedicated gpu
I enabled on Msi afterburner an option to see the power consumption and when my cpu is above 83° which is verry hot, I can see that the wat consumption go down from 25-30 to 15-20. Does this matter?
https://linustechtips.com/topic/1009459-cpu-problem/#findComment-12186316
Well again, unless the CPU is dropping below 2.6 GHz (which is its base clock speed) under a regular workload, I don't consider it to be thermal throttling.
https://linustechtips.com/topic/1009459-cpu-problem/#findComment-12187040
