Streamlabs OBS / elgato stream stutter
Solved by Tommybobberson,
4 minutes ago, jelle_vdd said:yes i did
where can i find that option ?
look at your devices in obs
Make sure your device for the game capture(on obs) says "game capture HD60 (video)#1" instead of "El.Gato HD capture" then set the buffering to disable. It(the buffering option) will only appear if you have the device set correctly
