Hey all! I’m from the USA and looking to build a new gaming pc. The only game I play is CSGO and some occasional fortnite. I play on low/med settings and want 180+ fps if possible. I’m looking to complete this build for under $500.
I have a spare i5-6500 that I’d like to use in this build.
any advice would help ❤️
https://linustechtips.com/topic/1009257-gaming-pc-help/
180+ FPS on csgo *
https://linustechtips.com/topic/1009257-gaming-pc-help/#findComment-12088556
If you need to buy a cooler, you can bump the SSD down to a 120GB, or the GPU down to an RX 580 4GB and buy a cheap cooler. You can also change the case out if you want something cheaper, smaller, or just different looking.
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/1009257-gaming-pc-help/#findComment-12088619
You are wonderful. Think I’m just gonna rock this setup.
https://linustechtips.com/topic/1009257-gaming-pc-help/#findComment-12088635
That's all you need homie.
Ryzen 3800X + MEG ACE w/ Radeon VII + 3733 c14 Trident Z RGB in a Custom Loop powered by Seasonic Prime Ultra Titanium
PSU Tier List | Motherboard Tier List | My Build
https://linustechtips.com/topic/1009257-gaming-pc-help/#findComment-12088661
