What power supply do you have?
Your CPU will most likely bottleneck your GPU, so keep that in mind.
https://linustechtips.com/topic/1008826-help/#findComment-12085443
3 minutes ago, LuckyOne said:
I believe I have a 500 or 600 wattage power supply. And what can I do to decrease the bottleneck, or should I invest into a better cpu @Crunchy Dragon
Even the top end CPUs on the FM2 platform aren't that good, I would personally save up a couple hundred and make the jump to Ryzen.
https://linustechtips.com/topic/1008826-help/#findComment-12085457
Well so the power supply would be good for the gpu, but which Ryzen do you recommend for someone like me on a budgets, such as under 200. Im trying to do a build currently and dont have much of a budget left
https://linustechtips.com/topic/1008826-help/#findComment-12085462
There's not much you can get in terms of Ryzen for $200.
I'd recommend hunting the used market for a 4th gen Core i5/i7 and motherboard bundle. Those are usually pretty cheap, if the sellers are decent people.
https://linustechtips.com/topic/1008826-help/#findComment-12085473
Just now, _d0nut said:
The 2600 is really solid, provided you can afford a decent b450 board
I was actually thinking. I don't know much about computers and I don't want to brick my system, so I have another pc that has an i5, asus motherboard and a hd already, so I think Ill put the gtx in there, get an ssd and buy a new case for it
https://linustechtips.com/topic/1008826-help/#findComment-12085519
What i5 is it? most i5’s should work with a 1050ti, especially if its overclockable
https://linustechtips.com/topic/1008826-help/#findComment-12085531
