Help with airflow
Go to solution Solved by LogicalDrm,
1 hour ago, Dekan256 said:
I have a Evga GTX 1050ti, although I'm not sure what type of cooling it uses.
Edit: After looking it up my card is open air.
Thats about cross-design, I think. Have both fans as intake, it might be bit better that way.
I'm still somewhat new to the world of having a half decent rig, and I'm looking at adding some more case fans but don't really know what orientation to install them. I have a Cooler Master Elite 110, it has a filtered 120mm front intake fan, and room to put two 80mm side fans. Right behind where the side fans would sit is where my GPU lives, and I have no idea if its better to have them act as additional intakes, or as a set of exhaust fans. Any advice is appreciated, thanks!
https://linustechtips.com/topic/1008728-help-with-airflow/
intakes will be my choice
Desktop benching:
https://linustechtips.com/topic/1008728-help-with-airflow/#findComment-12084673
Which GPU do you have? For blower style cooler, all intake. For open air, fan over fins should be exhaust. It might be worth of test to have both as exhaust if you have open-air cooled card.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1008728-help-with-airflow/#findComment-12086220
https://linustechtips.com/topic/1008728-help-with-airflow/#findComment-12087853
https://linustechtips.com/topic/1008728-help-with-airflow/#findComment-12088105
