have experienced the same thing before, tight cables.
just pull hard
probably a good idea to mount in in a case and try pulling it out to avoid the mobo from bending
Main Rig: CPU Intel Xeon X5660 (4.55Ghz @ 1.45v) / MOBO Asus ROG Rampage III Extreme / RAM 16GB Corsair Vengeance LPX1866 MHz / CPU COOLER ID-COOLING Frostflow+ 240 / GPU EVGA Titan X Hybrid (+630 core + 400 memory) / CASE Cooler Master CM 690 II Advanced + transparent side panel / SSD Crucial M550 512GB / PSU Cooler Master Silent Pro Gold 1200W / DISPLAY 1440p monitor / KEYBOARD Topre Realforce RGB / MOUSE Corsair Glaive Aluminum RGB / SOUND Creative Labs. X-Fi SoundBlaster Elite Pro / ROUTER Netgear R9000 X10 Wireless ad / OS Windows 10 Pro / DRIVING WHEEL Logitech G27
Web Server Rig: CPU 2x Intel Xeon X5680 / MOBO Supermicro X8DTL-i / RAM 64GB (2X32GB) SK-Hynix ECC LRDIMMs / CPU COOLER ID-COOLING Frostflow+ 120 + Corsair H50 AIO / GPU MSI GTX 1070 Gaming X (+250core +300 memory) / CASE NZXT Lexa S / SSD Kingston 120GB / HDD 4 x 3TB WD RAID 6 / PSU Enermax MaxRevo 1500W / DISPLAY 900p monitor / KEYBOARD Logitech / MOUSE Logitech
Actually Portable Laptop: HP Spectre x360 15' (Late 2018) / i7-8750H, 16GB RAM, 512GB SSD, GTX 1050Ti MaxQ, 4K Display / KEYBOARD Ducky One 2 Mini / OS Linux Mint 19 Cinnamon / WIRELESS ADAPTER NETGEAR A6210 USB 3.0
Bed Laptop: ASUS VIVOBOOK 15 / i5-8250U, 8GB RAM, 1TB Toshiba HDD, UHD 630, 1080P Display / OS Linux Mint 19 Cinnamon
Backup Rig: CPU Intel Xeon X3470 (4Ghz @ 1.4v) / MOBO MSI P55-GD80 / RAM 16GB HyperX 1600Mhz / CPU COOLER ID-COOLING Frostflow+ 120 / GPU Sapphire R9 270X (+150 core + 200 memory) / CASE Cooler Master Elite 343 SSD Crucial MX150 250GB / PSU Seasonic SS430-GB / KEYBOARD Logitech G910 Orion Spark / MOUSE Logitech / DISPLAY Dell SE2417HGR / OS Windows 10 Pro / WIRELESS ADAPTER
TP-LINK Archer T6E PCI-E
Server 1: DELL POWEREDGE 1950 / 2x Intel Xeon E5450, 16GB ECC, 4x 3TB Western Digital (Various) 7200RPM SATA HDD in RAID 6, GT 640 / DISPLAY Lenovo L2251p
Server 2: DELL POWEREDGE 1950 / 2x Intel Xeon E5420, 8GB ECC, 2 x 160GB SAS, GT 210
https://linustechtips.com/topic/1008563-24-pin-connecter-stuck/#findComment-12083348
You need to push the clip down first before you can remove the cable. That clip you see in the middle latches onto the plug, so just push that clip down first and then slowly remove the cable.
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
https://linustechtips.com/topic/1008563-24-pin-connecter-stuck/#findComment-12083349
Push the clip towards the cables? Im doing that, nothing moves
https://linustechtips.com/topic/1008563-24-pin-connecter-stuck/#findComment-12083365
You'll just have to pull hard on the 24 pin cable.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1008563-24-pin-connecter-stuck/#findComment-12083372
push the top of the clip and pull hard with one hand and hold the motherboard and connector down with the other so you dont rip off the connector. 24 pin cables are notorious for being a pain in the ass for being so tight they flex the motherboard
Builds:
https://linustechtips.com/topic/1008563-24-pin-connecter-stuck/#findComment-12083374
