  1. I decided to install Linux on my laptop. The first problem I have encountered is adding my Linux OS to my Windows Domain, I have everything setup on the server end possibly on my laptop.  Here is what I am using right now, i am currently using a Dell Latitude D530 with Zorin OS 7, which is a ubuntu based Linux Operating System
  • The error log I saved:
  • '20140111042100:VERBOSE:Found krb5 name value pair ' pkinit_anchors = DIR:/var/lib/likewise/trusted_certs'20140111042100:VERBOSE:Found krb5 name value pair ' pkinit_cert_match = &&<EKU>msScLogin<PRINCIPAL>'20140111042100:VERBOSE:Found krb5 name value pair ' pkinit_eku_checking = kpServerAuth'20140111042100:VERBOSE:Found krb5 name value pair ' pkinit_win2k_require_binding = false'20140111042100:VERBOSE:Found krb5 name value pair ' pkinit_identities = PKCS11:/usr/lib/likewise-open/libpkcs11.so'20140111042100:VERBOSE:Found krb5 name value pair ' default_keytab_name = /etc/krb5.keytab'20140111042100:VERBOSE:Found krb5 stanza '[domain_realm]'20140111042100:VERBOSE:Found krb5 name value pair ' .dmott-latitude-d530 = DMOTT-LATITUDE-D530'20140111042100:VERBOSE:Found krb5 stanza '[realms]'20140111042100:VERBOSE:Found krb5 compound statement ' DMOTT-LATITUDE-D530 = {'20140111042100:VERBOSE:Found krb5 name value pair ' auth_to_local = RULE:[1:$0\$1](^DMOTT-LATITUDE-D530\\.*)s/^DMOTT-LATITUDE-D530/DMOTT-LATITUDE-D530/'20140111042100:VERBOSE:Found krb5 name value pair ' auth_to_local = DEFAULT'20140111042100:VERBOSE:Found krb5 compound end ' }'20140111042100:VERBOSE:Found krb5 stanza '[appdefaults]'20140111042100:VERBOSE:Found krb5 compound statement ' pam = {'20140111042100:VERBOSE:Found krb5 name value pair ' mappings = DMOTT-LATITUDE-D530\\(.*) $1@DMOTT-LATITUDE-D530'20140111042100:VERBOSE:Found krb5 name value pair ' forwardable = true'20140111042100:VERBOSE:Found krb5 name value pair ' validate = true'20140111042100:VERBOSE:Found krb5 compound end ' }'20140111042100:VERBOSE:Found krb5 compound statement ' httpd = {'20140111042100:VERBOSE:Found krb5 name value pair ' mappings = DMOTT-LATITUDE-D530\\(.*) $1@DMOTT-LATITUDE-D530'20140111042100:VERBOSE:Found krb5 name value pair ' reverse_mappings = (.*)@DMOTT-LATITUDE-D530 DMOTT-LATITUDE-D530\$1'20140111042100:VERBOSE:Found krb5 compound end ' }'20140111042100:INFO:Reading nsswitch file /etc/nsswitch.conf20140111042100:ERROR:Unexpected file: /etc/lsb-release20140111042100:ERROR:Unexpected file: /etc/lsb-release20140111042100:INFO:Reading krb5 file /tmp/likewisetmpAQZy9o/etc/krb5.conf20140111042100:VERBOSE:Found krb5 stanza '[libdefaults]'20140111042100:VERBOSE:Found krb5 name value pair ' default_realm = DMOTT-LATITUDE-D530'20140111042100:VERBOSE:Found krb5 name value pair ' default_tgs_enctypes = RC4-HMAC DES-CBC-MD5 DES-CBC-CRC'20140111042100:VERBOSE:Found krb5 name value pair ' default_tkt_enctypes = RC4-HMAC DES-CBC-MD5 DES-CBC-CRC'20140111042100:VERBOSE:Found krb5 name value pair ' preferred_enctypes = RC4-HMAC DES-CBC-MD5 DES-CBC-CRC'20140111042100:VERBOSE:Found krb5 name value pair ' dns_lookup_kdc = true'20140111042100:VERBOSE:Found krb5 name value pair ' pkinit_kdc_hostname = <DNS>'20140111042100:VERBOSE:Found krb5 name value pair ' pkinit_anchors = DIR:/var/lib/likewise/trusted_certs'20140111042100:VERBOSE:Found krb5 name value pair ' pkinit_cert_match = &&<EKU>msScLogin<PRINCIPAL>'20140111042100:VERBOSE:Found krb5 name value pair ' pkinit_eku_checking = kpServerAuth'20140111042100:VERBOSE:Found krb5 name value pair ' pkinit_win2k_require_binding = false'20140111042100:VERBOSE:Found krb5 name value pair ' pkinit_identities = PKCS11:/usr/lib/likewise-open/libpkcs11.so'20140111042100:VERBOSE:Found krb5 name value pair ' default_keytab_name = /etc/krb5.keytab'20140111042100:VERBOSE:Found krb5 stanza '[domain_realm]'20140111042100:VERBOSE:Found krb5 name value pair ' .dmott-latitude-d530 = DMOTT-LATITUDE-D530'20140111042100:VERBOSE:Found krb5 stanza '[realms]'20140111042100:VERBOSE:Found krb5 compound statement ' DMOTT-LATITUDE-D530 = {'20140111042100:VERBOSE:Found krb5 name value pair ' auth_to_local = RULE:[1:$0\$1](^DMOTT-LATITUDE-D530\\.*)s/^DMOTT-LATITUDE-D530/DMOTT-LATITUDE-D530/'20140111042100:VERBOSE:Found krb5 name value pair ' auth_to_local = DEFAULT'20140111042100:VERBOSE:Found krb5 compound end ' }'20140111042100:VERBOSE:Found krb5 stanza '[appdefaults]'20140111042100:VERBOSE:Found krb5 compound statement ' pam = {'20140111042100:VERBOSE:Found krb5 name value pair ' mappings = DMOTT-LATITUDE-D530\\(.*) $1@DMOTT-LATITUDE-D530'20140111042100:VERBOSE:Found krb5 name value pair ' forwardable = true'20140111042100:VERBOSE:Found krb5 name value pair ' validate = true'20140111042100:VERBOSE:Found krb5 compound end ' }'20140111042100:VERBOSE:Found krb5 compound statement ' httpd = {'20140111042100:VERBOSE:Found krb5 name value pair ' mappings = DMOTT-LATITUDE-D530\\(.*) $1@DMOTT-LATITUDE-D530'20140111042100:VERBOSE:Found krb5 name value pair ' reverse_mappings = (.*)@DMOTT-LATITUDE-D530 DMOTT-LATITUDE-D530\$1'20140111042100:VERBOSE:Found krb5 compound end ' }'20140111042100:ERROR:Unexpected file: /etc/lsb-release20140111042100:ERROR:Unexpected file: /etc/lsb-release20140111042100:INFO:Found config file /etc/ssh/ssh_config20140111042100:INFO:Found binary /usr/bin/ssh20140111042100:INFO:Reading ssh file /etc/ssh/ssh_config20140111042100:INFO:Testing option GSSAPIAuthentication20140111042100:INFO:Testing option GSSAPIDelegateCredentials20140111042100:INFO:Running module join20140111042101:ERROR:Unexpected file: /etc/lsb-release20140111042303:INFO:Adding skula (fqdn skula.skull) to /etc/hosts ip 127.0.1.1, removing skula, skula.skull, skula, skula.skull20140111042303:INFO:Reading krb5 file /tmp/likewisetmpSINKUa/etc/krb5.conf20140111042303:VERBOSE:Found krb5 stanza '[libdefaults]'20140111042303:VERBOSE:Found krb5 name value pair ' default_realm = DMOTT-LATITUDE-D530'20140111042303:VERBOSE:Found krb5 name value pair ' default_tgs_enctypes = RC4-HMAC DES-CBC-MD5 DES-CBC-CRC'20140111042303:VERBOSE:Found krb5 name value pair ' default_tkt_enctypes = RC4-HMAC DES-CBC-MD5 DES-CBC-CRC'20140111042303:VERBOSE:Found krb5 name value pair ' preferred_enctypes = RC4-HMAC DES-CBC-MD5 DES-CBC-CRC'20140111042303:VERBOSE:Found krb5 name value pair ' dns_lookup_kdc = true'20140111042303:VERBOSE:Found krb5 name value pair ' pkinit_kdc_hostname = <DNS>'20140111042303:VERBOSE:Found krb5 name value pair ' pkinit_anchors = DIR:/var/lib/likewise/trusted_certs'20140111042303:VERBOSE:Found krb5 name value pair ' pkinit_cert_match = &&<EKU>msScLogin<PRINCIPAL>'20140111042303:VERBOSE:Found krb5 name value pair ' pkinit_eku_checking = kpServerAuth'20140111042303:VERBOSE:Found krb5 name value pair ' pkinit_win2k_require_binding = false'20140111042303:VERBOSE:Found krb5 name value pair ' pkinit_identities = PKCS11:/usr/lib/likewise-open/libpkcs11.so'20140111042303:VERBOSE:Found krb5 name value pair ' default_keytab_name = /etc/krb5.keytab'20140111042303:VERBOSE:Found krb5 stanza '[domain_realm]'20140111042303:VERBOSE:Found krb5 name value pair ' .dmott-latitude-d530 = DMOTT-LATITUDE-D530'20140111042303:VERBOSE:Found krb5 stanza '[realms]'20140111042303:VERBOSE:Found krb5 compound statement ' DMOTT-LATITUDE-D530 = {'20140111042303:VERBOSE:Found krb5 name value pair ' auth_to_local = RULE:[1:$0\$1](^DMOTT-LATITUDE-D530\\.*)s/^DMOTT-LATITUDE-D530/DMOTT-LATITUDE-D530/'20140111042303:VERBOSE:Found krb5 name value pair ' auth_to_local = DEFAULT'20140111042303:VERBOSE:Found krb5 compound end ' }'20140111042303:VERBOSE:Found krb5 stanza '[appdefaults]'20140111042303:VERBOSE:Found krb5 compound statement ' pam = {'20140111042303:VERBOSE:Found krb5 name value pair ' mappings = DMOTT-LATITUDE-D530\\(.*) $1@DMOTT-LATITUDE-D530'20140111042303:VERBOSE:Found krb5 name value pair ' forwardable = true'20140111042303:VERBOSE:Found krb5 name value pair ' validate = true'20140111042303:VERBOSE:Found krb5 compound end ' }'20140111042303:VERBOSE:Found krb5 compound statement ' httpd = {'20140111042303:VERBOSE:Found krb5 name value pair ' mappings = DMOTT-LATITUDE-D530\\(.*) $1@DMOTT-LATITUDE-D530'20140111042303:VERBOSE:Found krb5 name value pair ' reverse_mappings = (.*)@DMOTT-LATITUDE-D530 DMOTT-LATITUDE-D530\$1'20140111042303:VERBOSE:Found krb5 compound end ' }'20140111042303:INFO:Reading nsswitch file /etc/nsswitch.conf20140111042303:ERROR:Unexpected file: /etc/lsb-release20140111042303:ERROR:Unexpected file: /etc/lsb-release20140111042303:INFO:Reading krb5 file /tmp/likewisetmpU6alfc/etc/krb5.conf20140111042303:VERBOSE:Found krb5 stanza '[libdefaults]'20140111042303:VERBOSE:Found krb5 name value pair ' default_realm = DMOTT-LATITUDE-D530'20140111042303:VERBOSE:Found krb5 name value pair ' default_tgs_enctypes = RC4-HMAC DES-CBC-MD5 DES-CBC-CRC'20140111042303:VERBOSE:Found krb5 name value pair ' default_tkt_enctypes = RC4-HMAC DES-CBC-MD5 DES-CBC-CRC'20140111042303:VERBOSE:Found krb5 name value pair ' preferred_enctypes = RC4-HMAC DES-CBC-MD5 DES-CBC-CRC'20140111042303:VERBOSE:Found krb5 name value pair ' dns_lookup_kdc = true'20140111042303:VERBOSE:Found krb5 name value pair ' pkinit_kdc_hostname = <DNS>'20140111042303:VERBOSE:Found krb5 name value pair ' pkinit_anchors = DIR:/var/lib/likewise/trusted_certs'20140111042303:VERBOSE:Found krb5 name value pair ' pkinit_cert_match = &&<EKU>msScLogin<PRINCIPAL>'20140111042303:VERBOSE:Found krb5 name value pair ' pkinit_eku_checking = kpServerAuth'20140111042303:VERBOSE:Found krb5 name value pair ' pkinit_win2k_require_binding = false'20140111042303:VERBOSE:Found krb5 name value pair ' pkinit_identities = PKCS11:/usr/lib/likewise-open/libpkcs11.so'20140111042303:VERBOSE:Found krb5 name value pair ' default_keytab_name = /etc/krb5.keytab'20140111042303:VERBOSE:Found krb5 stanza '[domain_realm]'20140111042303:VERBOSE:Found krb5 name value pair ' .dmott-latitude-d530 = DMOTT-LATITUDE-D530'20140111042303:VERBOSE:Found krb5 stanza '[realms]'20140111042303:VERBOSE:Found krb5 compound statement ' DMOTT-LATITUDE-D530 = {'20140111042303:VERBOSE:Found krb5 name value pair ' auth_to_local = RULE:[1:$0\$1](^DMOTT-LATITUDE-D530\\.*)s/^DMOTT-LATITUDE-D530/DMOTT-LATITUDE-D530/'20140111042303:VERBOSE:Found krb5 name value pair ' auth_to_local = DEFAULT'20140111042303:VERBOSE:Found krb5 compound end ' }'20140111042303:VERBOSE:Found krb5 stanza '[appdefaults]'20140111042303:VERBOSE:Found krb5 compound statement ' pam = {'20140111042303:VERBOSE:Found krb5 name value pair ' mappings = DMOTT-LATITUDE-D530\\(.*) $1@DMOTT-LATITUDE-D530'20140111042303:VERBOSE:Found krb5 name value pair ' forwardable = true'20140111042303:VERBOSE:Found krb5 name value pair ' validate = true'20140111042303:VERBOSE:Found krb5 compound end ' }'20140111042303:VERBOSE:Found krb5 compound statement ' httpd = {'20140111042303:VERBOSE:Found krb5 name value pair ' mappings = DMOTT-LATITUDE-D530\\(.*) $1@DMOTT-LATITUDE-D530'20140111042303:VERBOSE:Found krb5 name value pair ' reverse_mappings = (.*)@DMOTT-LATITUDE-D530 DMOTT-LATITUDE-D530\$1'20140111042303:VERBOSE:Found krb5 compound end ' }'20140111042303:ERROR:Unexpected file: /etc/lsb-release20140111042303:ERROR:Unexpected file: /etc/lsb-release20140111042303:INFO:Found config file /etc/ssh/ssh_config20140111042303:INFO:Found binary /usr/bin/ssh20140111042303:INFO:Reading ssh file /etc/ssh/ssh_config20140111042303:INFO:Testing option GSSAPIAuthentication20140111042303:INFO:Testing option GSSAPIDelegateCredentials20140111042303:INFO:Running module join20140111042304:ERROR:Unexpected file: /etc/lsb-release[code=auto:0]
  • In short I get the error "DNS_ERROR_BAD_PACKET A bad packet was received from a DNS server. Potentially the requested address does not exist." when I try just SKULL.
  • When I try with SKULL.LOCAL I get "Lsass Error Network name not found.. Failure to lookup a domain name ending in ".local" may be the result of configuring the local system's hostname resolution (or equivalent) to use Multi-cast DNS. Please refer to the Likewise manual athttp://www.likewise.com/resources/documentation_library/manuals/open/lik...for more information."
This is the only couple of problems I am having with this portion, I tried using a static DNS Server, Static IP... I even tried to do some research on this problem and still didn't budge anywhere. I also edited the resolv.conf file which lead no where. I want to expand my networking into linux as I gain more knowledge of the Windows Side of Networking
     2. The next problem is adding my Network Printer. The configuration of my printer setup is with a Windows Print Server, I have installed all the required components on Windows Server 2008, which I don't know on the client side of things, but the error I get is "Bad device-uri "lpd://ADMINISTRATOR1/HP Deskjet D1400 series"." That is the only error I am getting right now. I went through Windows Firewall, and it has been allowed for LDP Service.
Any help will help me break ground on a little bit of Linux/Windows Networking.
SkullAbyss
https://linustechtips.com/topic/100849-linux-domain-and-network-printer-problem/
Hi, That log is pretty unreadable, please attach is using the
 tags to make sure line endings are preserved.
Arch Linux on Samsung 840 EVO 120GB: Startup finished in 1.334s (kernel) + 224ms (userspace) = 1.559s | U mad windoze..?
List out what is in your network config:
/etc/network/interfaces
Also
/etc/resolv.conf
Then type the following commands
/sbin/ifconfig -a
and
/sbin/route -v
This will tell us what is what with your networking.
If you configured your network with Network Manager then list what is there for your NIC(s). I personally hate  Network Manager and prefer to do the networking by hand because under some cases Network Manager will kill your network settings, live and learn.
I roll with sigs off so I have no idea what you're advertising.
This is NOT the signature you are looking for.
Also
/etc/resolv.conf
/sbin/ifconfig -a
and
/sbin/route -v
Results:
I did the /etc/network/interfaces, it was completely blank.
the /etc/resolv.conf was
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
#     DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
nameserver 127.0.1.1
search SKULL.LOCAL
/sbin.ifconfig -a
dmott@skula:~$ /sbin/ifconfig -a
eth0      Link encap:Ethernet  HWaddr 00:21:70:74:67:86
          inet addr:192.168.128.113  Bcast:192.168.128.255  Mask:255.255.255.0
          inet6 addr: fe80::221:70ff:fe74:6786/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:28501 errors:0 dropped:0 overruns:0 frame:0
          TX packets:19268 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:32507002 (32.5 MB)  TX bytes:3498357 (3.4 MB)
          Interrupt:17
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:1055 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1055 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:129247 (129.2 KB)  TX bytes:129247 (129.2 KB)
wlan1     Link encap:Ethernet  HWaddr 00:21:6b:06:60:da
          BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
/sbin/route -v
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
default         pfSense.localdo 0.0.0.0         UG    0      0        0 eth0
link-local      *               255.255.0.0     U     1000   0        0 eth0
192.168.128.0   *               255.255.255.0   U     1      0        0 eth0
SkullAbyss
