I get black screen while playing games, sometimes after 30mins, sometimes after 2hours of playing, followed with buzzing sound around 3-4 seconds than it stops, i can hear audio from game after that, but i cant get back without turning off pc. When i start the pc again, there is notification in windows 10 notification bar, it says "windows driver adapter failed to load". I updated my windows, also my GPU with the latest update on Nvidia experiance. I tryed few options to fix it, but it didnt help. Now im on the end of the road, i dont know what is the problem, probably GPU (temperature is around 70-85 when im playing), but i have a feeling if i buy a new one,problem wont be solved.
Intel core i5-2500 3.30ghz 64bit
Ram 8gb
GPU Nvidia GTX 750ti 2gb
PSU Fujitsu DPS-250AB-62 A
BIOS Insyde F.14 9/18/2012
Any advice would be helpful.
https://linustechtips.com/topic/1008239-black-screen-problem/
Are you overclocing your card at all? Does the card get good airflow, it could be that the vrms or maybe even the vram is overheating even though your GPU temps are high but perfectly safe for that card
Optical Drive Poll: https://linustechtips.com/main/topic/1006309-optical-drive-survey/
Main Rig (Pulsar)
CPU: Ryzen 7 5800X MOBO: MSI MEG X570 Unify RAM: Corsair Dominator Platinum RG(4x8gb) 3200Mhz 16-16-16-32 GPU: EVGA GTX 1080 FTW ACX 3.0 Cooler: Noctua NH-U12S Chromax (LTT Edition) Storage: Intel 6000p 128gb boot drive, Intel 665p 1tb (x2), Samsung 850 EVO 1tb, Case: Phanteks Enthoo Pro M Tempered Glass PSU: EVGA SupeNOVA G1+ 750W OS: Windows 10 Pro 64 bit
FreeNAS Server (The Vault)
CPU: Xeon E5-2603 v3 MOBO: MSI X99 Tomahawk RAM: G.Skill Aegis (4x8gb) 3000Mhz 16-18-18-38 GPU: EVGA GT 710 Cooler: Cooler Master Hyper 212 LED Storage: Intel S3520 x2 for boot, x16 in RAIDZ for storage, Seagate Ironwolf 2tb (Striped will be a steam cache) Case: Phanteks Enthoo Pro Tempered Glass PSU: Corsair CX750 750W
https://linustechtips.com/topic/1008239-black-screen-problem/#findComment-12080950
