 So I'm thinking about starting to build a gaming pc.
The games I play are
Red dead redemption
Fallout 74
Smite
Here would be my set up
Mother board
Intel i5 7640x
Evga dark x299 or
Gigabyte Aorus x299
Graphics card
Radeoen 470 8gb sapphire or
Asus strix 390 8gb
Memory
DDR4 8gb (2x4gb)
G.skill 2133 or
Off brand 2400 mhz
See pictures for details
https://linustechtips.com/topic/1008155-help-building-pc/
please don't waste your money on that platform, that chip or even anything around it. what is the budget for your upgrade, what is your location and anything else I need to know?
edit: some other parts need change too, but I'll show you after I have made something up
Edited by LukeSavenije
https://linustechtips.com/topic/1008155-help-building-pc/#findComment-12079839
What's your budget and location? Your current part list is crap.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1008155-help-building-pc/#findComment-12079841
1 minute ago, The curious James said:
1000
I have absolutly no idea of Hawaii"s pricings, so i'll do it with us and a margin
this would not only be cheaper, it would be more reliable, faster and look a lot less cheap, you have a waaaaaaaaaaaaay better upgrade path, am4 will be supported untill 2020. what do you think about it?
https://linustechtips.com/topic/1008155-help-building-pc/#findComment-12079863
lmao we both had (almost) the same idea
i guess this means i am learning something, if i put together a build that was similar to THE @LukeSavenije
just gonna throw this in here... the list i gave them had RGB soooooo
/s lol
✧・゚: *✧・゚:*  Quote for a reply  *:・゚✧*:・゚✧
✧・゚: *✧・゚:*   Ask for discord   *:・゚✧*:・゚✧
https://linustechtips.com/topic/1008155-help-building-pc/#findComment-12079868
/s lol
Thank you very much for your efforts dont care about rgb though
https://linustechtips.com/topic/1008155-help-building-pc/#findComment-12079872
/s lol
it was a fair try. but there aren't that many good matx boards for ryzen (yet). but that one isn't bad. in the other ways only your ssd and psu are better, but not required here.
btw, thanks for the compliment
https://linustechtips.com/topic/1008155-help-building-pc/#findComment-12079874
