dimension advice appriciated
Solved by GoldenLag,
seems fine. i wouldnt get more than 2*8GB of 3200mhz memmory however. unless you really need those 32GB. and even then i wouldnt get faster memmory.
would get an 8700k and a Z370 board instead of an 9000 series i5. that or skimp on the CPU a bit and get a 2600 and start saving towards an GPU upgrade
Edit:
CPU cooler: Dark rock 4 or Dark Rock Pro7 or Cryorig H7
