I wanna get into pc gaming and am looking to build something for around $900. Don't have a good idea of what games I will play but I don't want to be limited by not having enough power. I want to be able to play with a good frame rate even at high settings. I prefer Intel for the CPU but I know since they are a little pricey I might have to go with AMD but as long as I can still have my settings around high I'm good. Open to any suggestions.
https://linustechtips.com/topic/1006792-first-pc-build/
which country? need os/monitor/peripherals?
https://linustechtips.com/topic/1006792-first-pc-build/#findComment-12066504
1 minute ago, Str787 said:
I really just need advice on what motherboard and CPU to go with that I can expand later on. I think what Herman Mcpootis posted helped out my decision.
I'd say ryzen 2600/gtx1070 or rtx 2060 if it's any good/16gigs of ram/b450 mobo
https://linustechtips.com/topic/1006792-first-pc-build/#findComment-12066551
Here's my recommendation if you choose to go with Ryzen, although I omitted the case as that's up to you to decide, although personally I use the NZXT H500 which works very well out of the box.
With the extra budget you could easily upgrade to a GTX 1070ti or RX Vega 56
https://linustechtips.com/topic/1006792-first-pc-build/#findComment-12066552
Here's my Intel recommendation:
https://linustechtips.com/topic/1006792-first-pc-build/#findComment-12066561
Those specs look around what I was aiming for, my only concern is if the i5 is enough. Can I keep all those specs the same and put a i7 on that motherboard instead
https://linustechtips.com/topic/1006792-first-pc-build/#findComment-12066574
how do you make the PCP list formatted so well? ?
Don't worry about it, the i5 is pretty solid! If you want you can actually get a 9th gen i5 instead.
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
https://linustechtips.com/topic/1006792-first-pc-build/#findComment-12066582
For gaming it wouldn't make a substantial difference to choose between an i5 or an i7 (or between Intel and AMD for that matter because your GPU is going to be the bottleneck unless you go with a GPU that costs almost as much as your entire system). You could upgrade to an i7 8700 with the same Mobo, but you'd need to step up to a Z390 board if you wanted to go with a "K" series CPU. Keep in mind that I went with much cheaper RAM and a cheaper Mobo for Intel because the CPU I recommended is non-overclockable; if you wanted to go with an 8700K or a 9700K you'd far exceed your price range and have to upgrade the entire platform.
https://linustechtips.com/topic/1006792-first-pc-build/#findComment-12066590
Just now, leo1798 said:
I just copied over the permalink and it did the rest :)
oh wow, new feature I guess!
HOLA NIGHT THEMERS
OTHER TECH I OWN:
https://linustechtips.com/topic/1006792-first-pc-build/#findComment-12066601
Will it get 3.5 ghz or faster without getting into overclocking?
https://linustechtips.com/topic/1006792-first-pc-build/#findComment-12066611
