Locking my drive for programs
Solved by tzxazrael,
probably not, and if there is, it's going to be ridiculously esoteric and arcane. even for programs installed "on other drives", sometimes they require some, or a lot, of data put on your primary drive. eg; i once forced Office to install on a secondary drive, and the total install size seemed to go up by like 50% due to data being installed on both the secondary and main drive.
500gb SSD or M.2 is pretty cheap these days. install all your programs to C, and put all your games/movies/etc on your other drives. save the 120gb drive for a couple of "important" games that you want to run as fast as possible.
