I nead some help
resently my computer have all the HDD ocupide i dont know why i
try to fix this whit some tutorial in youtube and it was`t any
help so the only that i know is that my computer is super laggy, is
not a bad pc tho in general i can play some games do some work
 and whart ever. I have a hdd so may be that but i don`t think so ,i don`t
know i`m just a poor boy who need some help
btw sorry for bad ingles i`doning my best
https://linustechtips.com/topic/1006254-help/
1 minute ago, LukeSavenije said:
What is your question? Btw, you might want to use translate
I need some help recently my computer have all the HDD occupied, I don't know why, I try to fix this with some tutorial I found on youtube and it wasn't any help, so the only thing that I know is that my computer is super laggy, it is not a bad PC in general though, I can play some games, do some work, or whatever. I have an HDD but i don't thing that will do anything
https://linustechtips.com/topic/1006254-help/#findComment-12061720
So you have access to the windows task manager, you should be able to see what is taking up a lot of disk time. If that doesn't lead to anything I once had an SSD that was like that and the problem with it was the controller, that might be the thing for your HDD, I got it to work decently when I wiped it and reinstalled windows but  it was in a different computer, so a lot of variables changed.
https://linustechtips.com/topic/1006254-help/#findComment-12061734
Just now, barondeau said:
So you have access to the windows task manager, you should be able to see what is taking up a lot of disk time. If that doesn't lead to anything I once had an SSD that was like that and the problem with it was the controller, that might be the thing for your SSD
Well, this sounds more like a faulty hdd. Some testing says a lot sometimes
https://linustechtips.com/topic/1006254-help/#findComment-12061742
how can I check if it's the driver, and my pc is relatively new so I do not think that's it
https://linustechtips.com/topic/1006254-help/#findComment-12061781
What in task manager is using up all the disk
Optical Drive Poll: https://linustechtips.com/main/topic/1006309-optical-drive-survey/
Main Rig (Pulsar)
CPU: Ryzen 7 5800X MOBO: MSI MEG X570 Unify RAM: Corsair Dominator Platinum RG(4x8gb) 3200Mhz 16-16-16-32 GPU: EVGA GTX 1080 FTW ACX 3.0 Cooler: Noctua NH-U12S Chromax (LTT Edition) Storage: Intel 6000p 128gb boot drive, Intel 665p 1tb (x2), Samsung 850 EVO 1tb, Case: Phanteks Enthoo Pro M Tempered Glass PSU: EVGA SupeNOVA G1+ 750W OS: Windows 10 Pro 64 bit
FreeNAS Server (The Vault)
CPU: Xeon E5-2603 v3 MOBO: MSI X99 Tomahawk RAM: G.Skill Aegis (4x8gb) 3000Mhz 16-18-18-38 GPU: EVGA GT 710 Cooler: Cooler Master Hyper 212 LED Storage: Intel S3520 x2 for boot, x16 in RAIDZ for storage, Seagate Ironwolf 2tb (Striped will be a steam cache) Case: Phanteks Enthoo Pro Tempered Glass PSU: Corsair CX750 750W
https://linustechtips.com/topic/1006254-help/#findComment-12061790
2 minutes ago, gilbertmateo said:
nothing just 3 or 4 this using 0,1 MB/s
Thats odd, I would check for any driver updates on your motherboard manufacturers website as well as maybe even a bios or chipset update
Main Rig (Pulsar)
https://linustechtips.com/topic/1006254-help/#findComment-12061819
