PLEASE HELP!
Go to solution Solved by b emoji,
10 minutes ago, mdmme said:
Hey so I got a model m off ebay and I completely took it apart to clean it. This includes taking apart the black plastic rivets on the back of the metal plate. When I put it back together most of the keys stopped working and have very little click and feel awful. Does anyone know how I can fix this or if I should just give up and buy another one?
Oh, I know exactly what youre talking about. You're gonna need to do a nut and bolt mod. The mod with hopefully make the board work again and feel a lot better, I did this to my blue badge m and it feels a lot more crisp after it.
 https://wiki.geekhack.org/index.php?title=Modifications:IBM_Model_M:Nut_and_Bolt_Mod
https://linustechtips.com/topic/1006172-please-help/
Did you check by opening it again and seeing if you damaged anything or perhaps didn't reattach something all the way?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1006172-please-help/#findComment-12060859
https://linustechtips.com/topic/1006172-please-help/#findComment-12060877
Also what m did you get? The rainbow backplate space saver and industrial ones are real nice.
https://linustechtips.com/topic/1006172-please-help/#findComment-12060885
