Try pinging your default gateway (192.168.123.1) to see if its an issue with your router / the wireless connection or an ISP / internet routing issue.
Also an MTR would be better than a traceroute in this case. On Windows, try the utility http://winmtr.net/. On Linux distros, you can just install MTR from the apt package manager with apt install mtr and then you can run the command mtr google.com and run it for like a minute (by default it goes through one cycle per second)
My Build : AMD Ryzen 9 3950X - Asus Strix X570-E - 64GB G.Skill Trident Z Neo
- Gigabyte RTX 3080 Ti - 2TB Samsung 970 Evo Plus SSD - Corsair AX860i Power Supply
https://linustechtips.com/topic/1005686-internet-problem/#findComment-12062435
On 12/8/2018 at 1:46 PM, Flappie02 said:
I do have wireless, but I've had it for a few years without any problems and now it acts weird
Thus is the nature of wireless.  All it takes is one neighbor getting a new device or wireless of their own on a clashing channel to cause problems.
https://linustechtips.com/topic/1005686-internet-problem/#findComment-12063044
I ran it and this is what I got: MTR.TXT
https://linustechtips.com/topic/1005686-internet-problem/#findComment-12080317
