Hey everyone, I'm getting ready to build my first computer, and was hoping to get some feedback. Anyways, here's my parts list:
(2 x) Corsair - SP140 49.49 CFM 140mm Fans
Corsair - CXM 550 W 80+ Bronze Certified Semi-Modular ATX Power Supply
Corsair - Crystal 280X MicroATX Mid Tower Case
Zotac - GeForce GTX 1050 Ti 4 GB Mini Video Card
Silicon Power - A55 512 GB 2.5" Solid State Drive
Hitachi - Ultrastar 1 TB 3.5" 7200RPM Internal Hard Drive
Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory
Asus - ROG Strix B450-I Gaming Mini ITX AM4 Motherboard
CRYORIG - C7 40.5 CFM CPU Cooler
AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor
I know my GPU choice is grossly underpowered, but I ran out of money. The plan is to upgrade in a few months. Aside from graphics, do I need anything else/different?
EDIT: I know my CPU and motherboard are way overpowered for simply gaming, but I wanted a solid foundation to support major upgrading in the future. The price difference from "basic" to mid-tier is small enough I'd rather spend extra $$$ now and save myself the trouble of upgrading them in the future. (My EXTENSIVE 45 minutes of research found these two parts are the biggest pain to swap out)
https://linustechtips.com/topic/1005249-first-build/
Spend less on SSD, RAM, Mobo, and ditch the coolelr then get a much better GPU. Then you won't have to upgrade at all in the coming months/years.
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
https://linustechtips.com/topic/1005249-first-build/#findComment-12053038
7 minutes ago, Dubious Gaming: bl4z3 said:
I would get a Ryzen 3 and bump my GPU to a 1060 3GB it shouldent bottleneck much.
Why buy a MUCH weaker CPU to get just a 1060 3gb lul. When OP can cut back on other parts that aren't as important to the gaming experience (assuming it's what OP does with his PC).
https://linustechtips.com/topic/1005249-first-build/#findComment-12053046
My intent is to build a system that will take me way into the future, with only a couple upgrades every few years. I'm hoping this is a solid system that will manage games through 2023 with only graphics upgrades.
https://linustechtips.com/topic/1005249-first-build/#findComment-12053077
You won't need a 512 ssd nor a strix motherboard for that. What's your entire budget for the build?
https://linustechtips.com/topic/1005249-first-build/#findComment-12053095
