Cooler reccomendations?
Solved by WoodenMarker,
9 hours ago, BlitZerWolf2861 said:Shopee.com . Malaysia. Thanks
The normal Gammaxx 400 is a bit cheaper at 92 RM: https://shopee.com.my/DEEPCOOL-GAMMAXX-400-CPU-Cooler-4-Heatpipes-120mm-PWM-Fan-with-Blue-LED-i.42406182.732235649
What case are you using? If your case allows and you're willing to spend a bit more, there are better options.
Kotetsu MKII: https://shopee.com.my/SCYTHE-Kotetsu-Mark-II-Support-Intel-and-AMD-SCKTT-2000-i.7635397.1586747462
Ninja 5: https://shopee.com.my/SCYTHE-Ninja-5-Air-Cooler-Support-Intel-and-AMD-SCNJ-5000-i.7635397.1585146891
