CPU: Ryzen 5 2600 @ 3.2Ghz
Motherboard: MSI B450 Gaming Pro Carbon AC
RAM: Team Vulcan DDR4 16GB (2x8GB)
GPU: Zoatac Gtx 1070 8GB
Case: CoolerMaster Masterbox Lite 5 RGB
Storage: 2TB Toshiba HDD, 120GB WD Green SSD
PSUGigabyte P650B
https://linustechtips.com/topic/1004771-i-need-help/
Thanks, would you recommend a 1080p 1440p then
PSUGigabyte P650B
https://linustechtips.com/topic/1004771-i-need-help/#findComment-12051187
14 hours ago, Worstcaster said:
Ryzen comes with a pretty decent cooler, so you can probably remove that and put the money towards a SSD for the OS.  Other than that looks good.
Thanks I’ll investigate
PSUGigabyte P650B
https://linustechtips.com/topic/1004771-i-need-help/#findComment-12051190
