my display goes out within 30 mins of booting the computer its driving me insane!!!!
Ryzen 2700X
Kraken X62 AIO
Asus Prime X470-Pro
Nvidia GTX 1070TI Founders
16Gb Team Force Delta ram
EVGA 750w 80+ Gold
Ive rewired the entire computer and tried everything i can think of please help me
bios (updates/downgrades) Drivers (updates/fresh installs/uninstalls), cables (changed/inspected) HELP :'(
P.S. I use my Asus VG248 Monitor with my PS4 all the time with 0 issues so i dont think its the monitor but im about ti firmware update it
https://linustechtips.com/topic/1004712-please-help-no-display-issues/
Ryzen 2700X
Asus Prime X470-Pro
EVGA 750w 80+ Gold
Try testing the gpu on a different system and try testing your system with a different gpu. How long do you have this pc?
To be an expert is to know more about less.
  • 2014 Build --> FX 8350 4.7GHz {} ASRock Fatal1ty 990FX Killer {} Reference GTX 980 4GB {} 2x4GB 1866MHz HyperX {} Seagate 2TB 7200rpm {} 840 EVO 120GB {} XFX PRO850W {} Noctua NH D14 {} Fractal Define R4 White Windowed
  • 2018 Build --> Ryzen 7 2700X {} ASRock Fatal1ty X470 Gaming K4 {} Gigabyte RTX 2070 8GB {} 2x8GB HX Fury 3200MHz {} Toshiba P300 2TB {} Kingston 480GB A1000 {} Corsair RM750W {} Enermax LIQMAX II 240 {} Fractal Focus G
  • 2021 Build --> Ryzen 9 5900X {} ASUS ROG Strix X570-F GAMING {} ASUS GeForce RTX 3080Ti ROG STRIX OC {} Gigabyte AORUS RGB DDR4 32GB {} Kingston KC2500 M.2 2280 NVMe 2TB {} Seasonic FOCUS GX-1000 {} ASUS ROG Ryujin 240 AIO {} NYXT H710i
  • 2026 Build --> Ryzen 9 9950X3D {} ASUS ROG CROSSHAIR X870E HERO {} ASUS GeForce RTX 5090 32GB ASTRAL LC {} G.Skill TridentZ Royal Neo RGB Silver DDR5 CL28 6000MHz 2x16GB {} Samsung SSD 4TB 9100 PRO M.2 {} Seasonic 1600W PRIME TX Noctua Edition {} Fractal Lumen S36 V2 RGB 360mm AIO {} Fractal Design North XL Charcoal
10 minutes ago, SpinChilla said:
I only built it about 4/5months ago
Does the problem occur while gaming or is it always after 30 mins of booting the pc ?
The only thing you didn't try is reinstalling windows.
  • 3 weeks later...
yeah so this did not fix the issue this is still an issue ive tried 3 different monitor 4 different hdmi cables 2 different display cables read an article were a guy had the exact same issue and said it was his power supply tried a different power supply still having issues ive heard it could be my ram but i think i am defeated unless somebody magically figures it out please help
