OK, so I ordered the cooler master MF120R 3 in 1 fan pack, but they sent me just the fans without a controller. So, I contacted them and they gave me a refund so now I need to purchase an individual fan controller. I've been looking at them, but they all seem the same. Do you guys have any recommendations?
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
https://linustechtips.com/topic/1004670-good-fan-controller/
3 hours ago, LoGiCalDrm said:
You can control fans with mobo, and I'd recommend that instead of buying controller. If you need rgb controller, thats different thing.
I meant rgb controller HA, my bad. I found a cooler master one that works with ARGB fans, but if you know of any other ones, I'm open
https://linustechtips.com/topic/1004670-good-fan-controller/#findComment-12049659
For Coolermaster Fans, get the Coolermaster RGB controller. Unfortunately, most RGB controllers only work with same brand fans.
https://linustechtips.com/topic/1004670-good-fan-controller/#findComment-12049894
