Greetings fellow gamers! I play Battlefield V since the launch and I have problems with the FPS. The problem is this: All settings are on low for max perfomance at 1440p average frame rate 50-70 and sometimes 90-100 fps but many times big frame drops at 30-40 fps for 1-3 seconds. I then changed the res at 1080p but i get the exact same fps average. no difference at all same frame drops etc. My pc config is a Maximus V Extreme, Intel 3770K running at 3.9GHZ  and a Asus ROG STRIX 1070 OC edition the game is Installed in a SSD. The CPU usage while gaming is 100%... Is this CPU bottlenecking the GPU?
https://linustechtips.com/topic/1003818-frame-drops-on-bfv/
How much RAM do you have? Also might be CPU bottlenck since that i7 is pretty old
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
https://linustechtips.com/topic/1003818-frame-drops-on-bfv/#findComment-12040166
1 minute ago, Dezzin said:
Corsair Vengance Pro 16GB DDR3 at 2400MHz
Monitor CPU and GPU usage then. If you see GPU usage drops while CPU is at 100%, then it's most likely a CPU bottleneck.
https://linustechtips.com/topic/1003818-frame-drops-on-bfv/#findComment-12040194
Thanks I just need to be sure because all the rest of the games are playing fine and i am thinking of upgrading  the PC with a Asus ROG Strix Z390-F Gaming a Intel Core i5-9600K, 32GB of DDR4 and a new Corsair CPU watercooling system... but this will cost around 1000 euro and i needed to be sure about the CPU bottlenecking the GPU :)
https://linustechtips.com/topic/1003818-frame-drops-on-bfv/#findComment-12040236
CPU Usages SHOULD NOT STAY at 100% in Battlefield 5 on YOUR CURRENT setup.
It should be between 60-100%, usually around 70-85%, for the most part, you "should" be GPU bound even at 1080p.
Investigate this first.
I've just checked Youtube BF5 i7 3770 videos and this is not a common issue your having with this CPU.
https://www.youtube.com/results?sp=CAI%3D&search_query=battlefield+5+i7+3770+1070
Do you KILL browsers and other whatever programs..... your PC has running before Gaming? (Motherboard Program/Softwares?)
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/1003818-frame-drops-on-bfv/#findComment-12040238
