Hello, I have been looking for a mechanical keyboard and I'm having trouble finding one that fits my needs.
-Mechanical Keyboard (duh?)
-Ergonomic (kinda like the Logitech wave link for it )
-Custom RGB \ Programmable Keys
-Can unplug the cable from the keyboard (I break things) Like this
-Wrist rest would be nice but not super required
Appreciate any and all help :)
https://linustechtips.com/topic/1003593-keyboard-help/
There are options, but none of them are going to be cheep.
Your best bet will probably be the Ergodox: https://ergodox-ez.com/
The Kinesis Advantage is another option that's more ergonomic than an ergodox but lacks in the other features that you want  https://www.kinesis-ergo.com/shop/advantage2/
Custom building a Dactyl is doable but is a lot of work. http://xahlee.info/kbd/dactyl_keyboard.html
If you don't mind smaller form factors you have the Aterus62 https://shop.profetkeyboards.com/product/atreus62-keyboard
Then there's this thing....
https://x-bows.com/ This is $200 "only", but I'm convinced it's actually ergonomic. Seems more like a gimmick to me.
https://linustechtips.com/topic/1003593-keyboard-help/#findComment-12038000
