Heya guys! i just want to ask on how should i set up this QOS. basically, I just really need to focus my bandwidth to my PC, then the rest of the devices (tablets, phones, TV) will be evenly get the connection. Right now, the QOS option on my router (which was came from the ISP) is very vague and not easy for me to study. I have another router which i can use its QOS, but right now it cant get connected. I dont know much on networking, but i'm an easy learner :) if someone can just guide me, i'll do the rest of the work.
Thanks!
PS. See below for my current QOS setup, the IP i used is what my PC is using right now.
Ryzen 5 1600 | Gigabyte GA-AB350M-Gaming 3 | Team Elite TForce Delta RGB 2x8 16GB 3200mhz | Gigabyte GTX 1060 6GB AORUS | Fractal Design Arc Mini R2 | 2 1TB WD Blue | Wester Digital Blue 3D NAND 500GB | SeaSonic M12II 520W 80+ Bronze | CoolerMaster Hyper 212 Led Turbo | ASUS VG248QE | Rakk Kimat XT | Logitech G502 HERO | Massdrop x AKG M220 Pro | V8 Soundcard | BM800 Condenser Mic | Logitech C310
https://linustechtips.com/topic/1003539-help-qos-setting/
my recommendation, get a new router, most routers that are around $100 are better than the ones you get from your provider. I recommend linksys router's, ive been using them for years, and they very easily out perform even the top notch verizon gigabit router in my area. With linksys you can name each device and then it is as easy as dragging your favorites to the top of the QOS column. If you want any recommendations let me know.
https://linustechtips.com/topic/1003539-help-qos-setting/#findComment-12037289
