Need small form factor case suggestions
Title
Budget: I'd like to stay below $80 USD.  I will be modding this case so I'll be removing paint and plasti-dipping it.
Requirements:
Side tempered glass panel
Decent airflow, it won't be running anything too heavy
Anything under mid-atx is fine with me
Micro ATX
Preference:
I'd like to have the front panel a sort of closed front face with airflow coming in from either the top or bottom, similar to how the NZXT h500 does. Reason being, I am going to paint this thing and my vision has the front panel being similar to the h500. If all else fails, I'll just purchase a h500 case and mod that.
Suggest away my friends!
https://linustechtips.com/topic/1003532-need-small-form-factor-case-suggestions/
Q300L Is a really good, cheap MATX case
Any clue as to how the airflow is? The front seems to have good airflow, but I'd like to know for sure.
I should probably put this in as a "preferred" kind of thing, but I would like a closed front panel with air ventilation coming in through grooves via the bottom or the top of the front face panel. Similar to the h500 if that helps explain what I mean.
Airflow is good, but maybe you're looking for something like the Define Mini C? But it's kinda out of your price range
Jk its on sale on Newegg for 70$
Link
Link
Actually, that looks freaking perfect, thanks! I should have remembered this from one of the ads by JayzTwoCents or BitWit lol.
4 minutes ago, Dissitesuxba11s said:
Thermaltake Core V21 Comes with a 200mm fan.
Though it's not what I'm looking for, it looks fun to build in. It remind me of a short stubby bulldog, that's probably what I would call it :P
The Define C cases are awesome, hope you like building in it ;)
