24 minutes ago, immaguy1234 said:
I already seen that laptop but im looking for another one.
Im going to see how to cpu and gpu work.I know that it is 10% slower than the i5-8300H in gaming.But the i7-7700HQ is 2% better in gaming than the i5-7300HQ. But i will se what notebookcheck says because they are more accurate
Location? Any preference on weight and display quality?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
Check out the HP Omen 15. I have the 8th gen i5 with a 1050ti, 12 gigs ram, 128  gb m.2, and 1tb hdd. Picked this version up for 700 usd. The 1060 version is about a hundred bucks more.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
I recommended this to someone with the same budget this morning. Go for this one.
Just message or quote me if you have questions! I might not be able to answer them, but I might be able to help!
Current PC
Way too crappy to even say.
I found which laptops I pick out of
I saw that laptop and where can you get it for that cheap because the gtx 1060 version is over 1000
MSI GV62 8RE-061 $799
Hp pavilion gaming 15-CX0077WM $899
Dell G5 587-5859BLK $849
Asus FX503VM-NS52 $799
Which one of those laptops should i buy
This. But has low sRGB IPS and quite bulky
Desktop specs:
2 hours ago, AverageGamer2017 said:
You aren't going to say why not to choose the other ones
Build quality and cooling. Main priorities.
Desktop specs:
19 hours ago, AverageGamer2017 said:
MSI GV62 8RE-061
Go for this one. It's a reasonable price for the specs. Plus MSI is a trusted laptop brand (not saying that Dell and HP aren't, but they don't specialize in gaming).
Current PC
You keep saying build quality. Iphones has a good build quality but it sucks at doing most thing other phones can do. The temps of both the Dell and Msi are near the same with full load
Oof to the I-Phones **Nokia Lyfe.** Yes, the build quality is a bit better, but not enough for the extra cost (shut up I know it's the components). Similar temps, my dude.
Current PC
@GeneXiS_X keeps saying that the Dell g5 has better cooling but people who have the laptop have had their cpu temps quickly rise to over 90c and had to undervolt.
If you don't trust what I said, fine. I don't have time to explain to you. Just ignore my comment.
Desktop specs:
I know what you saying is true. But build quality and thermals aren't the only main priorities. You have display quality, Cpu and GPU performance, SSD performance. You only named two things and websites that have reviewed the dell g5 and MSI gv62 have rated them similar. Also, I think you should rethink about how the dell g5 has better cooling because people who have the laptop are having overheating problems.
