if this is the wrong place to post im sorry.
i whant to use the TP ports on the rt-n66u.
1.First modem (in bridge mode)
2.Ruter (Nighthawk(R) X4S R7800)
2.1 Pc1
2.2 Pc2
2.3 Pc3
3.wireless access point (rt-n66u)
3.1 Pc4 (this one is not getting ip from 2.) dont got net.
Somone know what i need to do?
https://linustechtips.com/topic/1002890-wireless-access-point/
11 minutes ago, WordFamer101 said:
The range and signal is all good. i get the rt-n66u conected. but the tp ports dont work it seams.
I assume you're using the LAN ports and not the WAN port?
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1002890-wireless-access-point/#findComment-12031965
