Hello guys god night. I have question i about get some fans on my case but my plans are all 120mm : 1 on the front 2 on the botom near my gpu on 1 the side panel near the gpu all of this ones has intakes and 1 at the top for exhaust and my psu fan acts as exhaust my psu is on the top of the case but the fan it self is on the down part of the psu am i good with this setup? thx in advance.
https://linustechtips.com/topic/1002788-case-fans/
2 minutes ago, Hernani Duarte said:
I have kind sleeper build asus m32
I'm not seeing how your plan works with the case. It looks like it only has provisions for a front and rear fan. The holes on the side look like they're only for ventilation. And I don't see a top fan mount.
Can you take a picture of the case you're working with? Maybe I'm looking at the wrong model.
https://linustechtips.com/topic/1002788-case-fans/#findComment-12031009
