Seeing how I decided not to upgrade my system this year, I would like to upgrade my headphone/headset solution. Currently I use a LG Tones (the cheaper ones) connected to my PC via this :https://www.amazon.com/gp/product/B0775YF36R/ref=oh_aui_detailpage_o01_s01?ie=UTF8&psc=1 adapter. So far it works great, and the LG tones provide good enough audio for me. The reason I want something new is because I really dont like in ear headphones as much as I like Over the ear headphones. I had a pair of Hyper X Clouds but wore a hole thru the wire and they stopped working, though they did last over 2 years so I would say thats pretty good for me. I like the idea of Blue Tooth because its universal. I can use my Tones on my desktop, laptop and Phone with ease and I dont have the worry about the wires being messed up. Which is what has happened with every headset I have ever had.
Must haves:
Around $100 or less
Over the ear
10+ hours of battery life
Comfortable
Would like:
Battery life indicator, either thru Windows 10 or Physically on the device.
3.5 mm jack support so I can use it with my Nintendo Switch
Carrying case for when I travel
Also thinking about using this headphone stand: https://www.amazon.com/Headphone-Charger-Charging-Earphone-Headphones/dp/B0719R8L6S/ref=pd_ybh_a_17?_encoding=UTF8&psc=1&refRID=CHBP218ME9C7172J6DZD
I was looking at these https://steelseries.com/gaming-headsets/arctis-3-bluetooth but not sure how Steel series is when it comes to audio. I learned long ago to stay away from Logitech headsets.
https://linustechtips.com/topic/1002672-bluetooth-audio/
I personally use Sennheiser Momentum Bluetooth on ear(over ears exists). Really enjoy them for music on the go and such. If you are going to play video games i would not use them in bluetooth though. Tried using them on my macbook in CSGO and the delay was horrible, so i started using them with cable but still the directional sound isn't too good. They include a removable cable, witch i personally only used on planes or while gaming. Battery life is really good(22 hrs) but unfortunately they are out of your budget.
https://linustechtips.com/topic/1002672-bluetooth-audio/#findComment-12033693
Yeah they are going to be used for gaming, Movie watching, Youtube, Hulu. I dont need audiophile grade, like I said, my LG tones sound fine, I just dont like the in ear variety.
https://linustechtips.com/topic/1002672-bluetooth-audio/#findComment-12033718
23 minutes ago, Zombiesnax said:
You could check out the Sennheiser HD 4.40
In Norway they are priced to 116 USD.
Thanks for the suggestion. They are $99 US, at least directly thru Sennheiser and thru Amazon. Im going to check locally I think, regardless if I buy online or Local I still have to pay Sales tax.
https://linustechtips.com/topic/1002672-bluetooth-audio/#findComment-12033812
