  • Describe the problem you are having in detail but without rambling. If your post is as long as this one, it's too long.
    • My problem is everything is running smoothly but I'll get random frame stutters even when the CPU and GPU aren't under full load.  Sometimes if I restart my computer it fixes it, but I just built it and want it running smooth from the start.
  • Include your operating system including version and 32/64 bit.
    • Windows 10 64bit.
  • Include your entire system specs, including the wattage of your PSU.
    • GTX 1080TI - Zotac Amp! Edition (11gb)
    • MSI MPG Z390 Gaming Edge AC Motherboard
    • Intel i7 8700k
      16Gb ram 3200 (XMP active)
      coolermaster aio 240ml cooler
      850w psu
      500gb ssd + 2 tb hdd
      6 fans in my case.
  • Tell us which BIOS version you have. Some problems can be fixed by updating to the latest BIOS, so check that there are no updates available
    • BIOS version A0.00 - have not updated BIOS.
  • Include any software running when it crashes (if applicable)
    • NVidia Share
    • Assassin's Creed Origins and Uplay/Final Fantaxy XV and Steam
  • Give full details of any error messages and screenshots if possible
https://linustechtips.com/topic/1002398-frame-stutter-issue-with-1080ti/
Disable your Antivirus and Windows Defender, I have this happen when an unexpected scan occurs
My rig:
CPU: Ryzen 7 5800x
MB: Gigabyte B450 I Aorus Pro WiFi
RAM: Kingston Fury Beast RGB 32GB (2x16GB) 3600mhz CL16 (1-to-1 Infinity Fabric enabled)
GPU: Gigabyte RTX 2080 Super
*bought for $200 CAD off a friend who needed an RTX 3080, price was my reward.
CASE: InWinn A1 Plus in White with included 600w gold sfx PSU and included custom length cables
DISPLAY: 3x 20" AOC 1080p 60hz 4ms ,  32" RCA 1080p/60hz TV mounted above, all on a single arm.
Storage: C : 1TB WD Blue NVMe      D : 2TB Barracuda      E: 240GB Kingston V300 (scratch drive)
NAS: 240GB Kingston A400 + 6x 10+ year old 700GB Barracuda drives in my old FX8350+8GB DDR3 system
Logitech G15 1st Gen + Logitech G602 Wireless
Steam Controller +  Elite Series 2 controller + Logitech G29 Racing Wheel + Wingman Extreme Digital 3D Flight Stick
Sennheiser HD 4.40 Headphones + Pixel Buds 2 + Logitech Z213 2.1 Speakers
My Girlfriends Weeb-Ass Rig:
Razer Blade Pro 17 2020
10th Gen i7 10875H 8c/16t @5.1ghz
17.3" 1080p 300Hz 100% sRGB, factory calibrated, 6mm bezel
RTX 2070 Max-Q 8GB
512GB generic NVMe
16GB (2x8GB) DDR4 3200Mhz
Wireless-AX201 (802.11a/b/g/n/ac/ax), Bluetooth® 5.1, 2.5Gbit Ethernet
70.5 Whr Battery
Razer Huntsman Quartz, Razer Balistic Quartz, Razer Kraken Quartz Kitty Heaphones
*deep breath*
Razer Raptor 27" monitor, IT'S BEAUTIFUL.
Here's a thought though, update the BIOS maybe??
My rig:
CPU: Ryzen 7 5800x
RTX 2070 Max-Q 8GB
512GB generic NVMe
70.5 Whr Battery
*deep breath*
Could it be that both of those games are WIDELY known for shit framepacing and stuttering., among other issues (across many varying systems)
And your PC is quite fine,... dealing with semi optimized / un-optimized  garbage time to time you will see a NOT perfect situation with software out of your control.
So what I'm saying is.... what other games do this? Because the two you mention, thats "Almost Normal" to come across in these games.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
When it happens, it happens across every game.  I chose those as examples of ones which hold up under load but when I restart, everything is okay.
1 hour ago, SpiralTTGL said:
could be standby memory problem you can use Intelligent standby list cleaner made by the guy who made the DDU application
What does a standby memory problem mean and what does intelligent standby list cleaner do to fix it?
This could be it actually, I use bitdefender and it is notorious for that.
The motherboard manufacturer suggested not to update the BIOS unless I change hardware to something unsupported on my current version, but everything should be fine as is I think?  Let me know if I am wrong - I asked MSI over the phone about BIOS updates and they said not to bother.
its a window's bug it causes some issue's with studdering been an issue for over a year, some game's don't suffer studdering but instead reduced framerate
here's a vid showing what diff it does
the Graph going all the way up or relatively high = studder
Intelligent standby list cleaner doesn't let the standby memory fill up completely by wiping it when it's almost at the max capacity
