I need advice on my new build.Below are the specs but I wanna know if everything seems good and if the 2600x is a good pair for the 2070 or maybe if I should wait for 3rd gen Ryzen although the new 2600x with the Wraith Max seems pretty nice.Im not exactly new to PC's since I had a used one with a GTX 780 and a FX 8350 but my cat peed on it ?.But anyway im opened to suggestions since this is gonna be my first build and my first time building a PC too.My budget is 1300$(could push for 1400$ if needed)
**CPU** | [AMD - Ryzen 5 2600X 3.6 GHz 6-Core Processor](https://pcpartpicker.com/product/6mm323/amd-ryzen-5-2600x-36ghz-6-core-processor-yd260xbcafbox) | $219.99 @ B&H
**Motherboard** | [MSI - X470 GAMING PLUS ATX AM4 Motherboard](https://pcpartpicker.com/product/4D7v6h/msi-x470-gaming-plus-atx-am4-motherboard-x470-gaming-plus) | $139.00 @ B&H
**Memory** | [G.Skill - Trident Z RGB 16 GB (2 x 8 GB) DDR4-3000 Memory](https://pcpartpicker.com/product/qjM323/gskill-trident-z-rgb-16gb-2-x-8gb-ddr3-3000-memory-f4-3000c16d-16gtzr) | $124.99 @ Newegg
**Storage** | [ADATA - Ultimate SU800 128 GB 2.5" Solid State Drive](https://pcpartpicker.com/product/mPgPxr/a-data-ultimate-su800-128gb-25-solid-state-drive-asu800ss-128gt-c) | $28.99 @ Amazon
**Storage** | [Western Digital - Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive](https://pcpartpicker.com/product/MwW9TW/western-digital-internal-hard-drive-wd10ezex) | $44.85 @ OutletPC
**Video Card** | [MSI - GeForce RTX 2070 8 GB Video Card](https://pcpartpicker.com/product/MR97YJ/msi-geforce-rtx-2070-8gb-video-card-geforce-rtx-2070-armor-8g) | $499.99 @ Newegg
**Case** | [NZXT - H500 (Black) ATX Mid Tower Case](https://pcpartpicker.com/product/p8x2FT/nzxt-h500-black-atx-mid-tower-case-ca-h500b-b1) | $69.99 @ B&H
**Power Supply** | [Corsair - CXM 650 W 80+ Bronze Certified Semi-Modular ATX Power Supply](https://pcpartpicker.com/product/R2mxFT/corsair-power-supply-cp9020103na) | $59.99 @ Amazon
| *Prices include shipping, taxes, rebates, and discounts* |
 | Total (before mail-in rebates) | $1207.79
 | Mail-in rebates | -$20.00
 | **Total** | **$1187.79**
 | Generated by [PCPartPicker](https://pcpartpicker.com) 2018-11-29 18:04 EST-0500 |
https://linustechtips.com/topic/1001856-build-advice/
7 minutes ago, Mib378 said:
My budget is 1300$
Check out this build:
5 minutes ago, Darpyface said:
Looks good, you may want to get a M.2 SSD for this price.
M.2 is a form factor, not an interface. M.2 SSDs can be both SATA or PCIe, so not all of them are fast. Don't give advice to people unless you know what you're talking about, thank you!
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1001856-build-advice/#findComment-12022837
Get a larger SSD.
128GB is nothing these days just like 240GB.
By the time u install windows and do all the updates and so on and so forth then space soon gets used up.
My advice is a 500GB or above SSD.
MSI MAG X670E TOMAHAWK WIFI Motherboard, AMD Ryzen 9 7900X3D Desk-top Processor (12-core/24-thread, 140MB cache, up to 5.6 GHz max boost), CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6000MHz CL30 AMD EXPO iCUE Compatible Computer Memory, Samsung 990 PRO NVMe M.2 SSD, 2 TB, PCIe 4.0, 7,450 MB/s read, 6,900 MB/s write, Internal SSD, 2 x Seagate BarraCuda 4 TB Internal Hard Drive HDD – 3.5 Inch SATA 6 Gb/s 5400 RPM 256 MB Cache for Computer Desktop PC Laptop (ST4000DM004), MSI MPG A1000G PCIE5 Power Supply Unit, UK Plug - 1000W, 80 Plus Gold Certified, Fully Modular ATX 3.0, PCIe 5.0 GPU, XILENCE XC982 LQ240PRO AIO COOLER, XFX Speedster MERC 310 AMD Radeon RX 7900 XT 20GB 1 x AOC CU34G2XE & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 970 Evo Plus NVME PCI-E 1TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 4TB Seagate Barracuda SATA III,  MZHOU 7 Ports PCIe USB 3.0 Card,  2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Fractal Design Pop XL Case + 4 Fractal Design 140mm Case Fans, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Third PC (Old Trustie) - Acer Aspire M3400, OEM Mainboard, AMD FX Athlon II X3 425 2.7Ghz, 16GB Corsair Value 1600Mhz Ram, OEM CPU Cooler, AMD R7 260 2GB GPU, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 2TB Samsung SATA III, 1 X OEM 16X DVDRW, 1 X Acer OEM Case, 1 X Corsair AF120 Case Can, Corsair CX500 Bronze+ CPU, Logitech MX Master Mouse, Corsair K30 Keyboard, Windows 10 Home X64 OEM, Logitech C920 Webcam, Bit Defender Total Security 2021.
Printers Include - Canon MG5750, Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer AX6000 Cable Router Wifi6 with a Virgin Media Hub 4.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S21+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/9935039193
https://linustechtips.com/topic/1001856-build-advice/#findComment-12022840
Well ATM I'm waiting for the Ryzen 2600x with the Wraith Max to drop since that cooler is not bad at all from what I've heard.
https://linustechtips.com/topic/1001856-build-advice/#findComment-12022913
22 minutes ago, jimkirk363 said:
Get a larger SSD.
I just need the SSD to boot from it so I guess I could get a 250gb.
https://linustechtips.com/topic/1001856-build-advice/#findComment-12022919
The NH-U12s is better than the Wraith Max
https://linustechtips.com/topic/1001856-build-advice/#findComment-12022981
The Wraith max will be fine unless hes planning overclocking.
Internet Speed.....
https://linustechtips.com/topic/1001856-build-advice/#findComment-12022992
